Switching to Synthetic
  • 21 Replies
  • 4509 Views
Offline the_maplebar
  • 466
« on: March 28, 2005, 03:24:29 AM »
I've been watching the different threads on oils, and I've decided that I'm going to switch to synthetic.  I have an 02 2.5L V6 with 42000 miles.  It has had regular changes every 3k - 4k mile with Pennz 10w-30 (oops :-/ I've just been reading about how 10w-30 can be bad with the V6 engines).  Anyways I'm wondering if there is any prep work I need/should do before making the switch?  I'm assuming I should use and engine flush kit/product beforehand, or is that not really necessary?  Also, any recomendations on a product?  So far I have seen Gunk- Motor Flush, Valvolline - Engine Flush and AMSOIL - Engine Flush.
Re: Switching to Synthetic
« Reply #1 on: March 28, 2005, 05:40:18 AM »
I have used gunk befor seamed ok, just make sure that you  put some regular oil and new filter on it and run it for a while befor you waste your new synthetic oil.
Offline trackinstile
  • 435
« Reply #2 on: March 28, 2005, 09:29:51 AM »
I was thinking about doing the same thing.  Anybody use Castrol Syntec?  Or does everyone use Mobile 1.  I think Castrol is a little cheaper.  Thanks, Dave
  • 466
« Reply #3 on: March 28, 2005, 10:11:49 AM »
And on a similar note, does anyone use AMSOIL?  If the product is half of what they hype it up to be it sounds interesting.  1/year oil changes would be nice, although I would probably still change it 2/year when changing the oil filter.  What's up with that, you supposed to change the oil filter but not the oil!!!!
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #4 on: March 28, 2005, 10:55:07 AM »
I would never use Gunk, etc on any engine of mine. If you want to clean the inside of your engine this is the only way to go: http://www.auto-rx.com/
Learn all you want to know about oil here: http://theoildrop.server101.com/ubb/ultimatebb.php
My opinion, synthetic is a waste of money if you change your oil every 3000 or so miles and Pennzoil 5w30 is good stuff.
Offline 3wheelerdude
  • 70
« Reply #5 on: March 28, 2005, 11:12:30 AM »
How would it be a waste of money if it doesnt cost more?? At the rate I put mileage on my car, changing the oil every 10 000kilos instead of every 5000 saves me alot of time and everyone knows that time is money...
« Last Edit: March 28, 2005, 11:13:00 AM by 3wheelerdude »
2000 Mustang
1996 Sidekick
1989 Tempo
1987 F150
Offline TN_Tracker
  • 1113
« Reply #6 on: March 28, 2005, 11:25:31 AM »
I don't think you read what I wrote. If you go 6,000 miles (10,000 kilometers) like you say you do then it's worth the synthetic. I said if you change your oil every 3,000 it's a waste of money to switch to synthetic. A good dino oil can go way longer than 3,000 anyway.
  • 70
« Reply #7 on: March 28, 2005, 12:50:58 PM »
Sorry bout that, I misunderstood...... and I agree 100% with what your theory.. ;)
2000 Mustang
1996 Sidekick
1989 Tempo
1987 F150
Offline wolf66
  • 193
« Reply #8 on: March 28, 2005, 02:08:57 PM »
Dino Vs Synthetic
Dino oil is a refined crude. Refining isn't a perfect process, so there will still be impurities in the finished product.
Dino oil contains paraffin, which over-thickens the oil when cold, in turn greatly increasing the load on your starter and eating fuel economy.
Any refined oil is made up of molecules that vary in size. Smaller molecules evaporate more readily, leaving larger molecules behind and causing the oil to get thicker with age.
These varying molecules also limit the friction-reducing ability of the oil.
On the other side of the coin, here's why we prefer synthetics:
Being a manufactured product, synthetic engine oil molecules are very uniform in size, meaning evaporation has minimal impact on viscosity.
Synthetic oil molecules are also rounder in shape than refined oil molecules, giving them superior lubrication characteristics.
Synthetic oils maintain a more constant viscosity over a wider temperature range, meaning it's safer to tag high RPM on a cold engine because a synthetic oil film is less likely to break down. (Analogous to tearing a piece of cold clay.)
A lubricant that's very slippery reduces frictional power loss and improves fuel economy.
http://www.overboost.com/story.asp?id=1092
'96 Suzuki X90-4" lift-snorkle-30x9.5's on 8x15 wheels-5.12 gears-winch-added rear seat-DT header-PioneerMP3-CB-GPS-roof rack-rear mounted full size spare
  • 435
« Reply #9 on: March 29, 2005, 12:30:36 AM »
Just wondering, does anyone use Castrol Syntec instead of Mobil 1?
  • 435
« Reply #10 on: March 29, 2005, 09:37:11 AM »
I'm taking the day long silence in here as a "NO" ;D
Offline TN_Tracker
  • 1113
« Reply #11 on: March 29, 2005, 09:42:55 AM »
How about a "did". I used it in my Vanagon and it worked fine but no better than GTX.
  • 435
« Reply #12 on: March 29, 2005, 10:12:30 AM »
Ok, thats good to know, I use the regular GTX, have been for about 12 years and I'd have to say at least 8 diffrent cars and trucks plus both my Suzukis, and never really had a problem.  Only thing that got me thinking about it is the timing chain tensioner making a little noise on the 2.0.  Thanks,   Dave ;D
Offline TN_Tracker
  • 1113
« Reply #13 on: March 29, 2005, 10:22:20 AM »
I know you must use 5w30 but from what I've read 0w30 is the good stuff. Made in Germany and it can sometimes be found at Autozone and Advance. It says made in Germany on the back of the bottle. Expensive. :o
Offline bandit86
  • 1641
  • elv8rguy
« Reply #14 on: March 29, 2005, 10:32:09 AM »
I always used 10W30, and had a leaking cam seal. changed to 5W30, the leak went away by itself.
