very happy (quickley went to angry)
  • 33 Replies
  • 8081 Views
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: very happy (quickley went to angry)
« Reply #15 on: March 27, 2005, 03:52:21 PM »
Checked your oil level lately? Maybe you are hearing some valve clatter. The Goblin seems to make some noise as well...
Offline mahimahimo
  • 377
« Reply #16 on: March 27, 2005, 04:04:04 PM »
thats what i thought at first but it seems to loud to be vavle chatter but ill deff check
Offline 92Sidekick4x4
  • 1456
« Reply #17 on: March 27, 2005, 05:43:45 PM »
mien ticks too but also on my friends it does, hhmmm i dunno
Offline mahimahimo
  • 377
« Reply #18 on: March 27, 2005, 06:01:38 PM »
its weird cause it started hapenin after i put the header on idk what it is and im kinda worried......quick question when i was putten the header on i yanked off the factory header and the factory header used a metal gasket...i didnt use that i used the one calmini gave me ...do u think it could have a leak cause of a faulty gaskit? also im not running a cat i removed it.... could that possibly have somethin to do with it and does the length of the wires i used to extend  the o2 sensor with affect it in any way?
                    -mo
« Last Edit: March 27, 2005, 06:04:20 PM by mahimahimo »
  • 1456
« Reply #19 on: March 27, 2005, 06:07:33 PM »
im not too sure as i have a aftermarket o2cenbsor and i didnt need to do anythign to the wire, i also am envriomentally firendly  ;D and i removed my cat so i couldnt tell yeah
« Reply #20 on: March 28, 2005, 02:47:59 AM »
Check your spark plug wires,
look at night with the hood up
and engine running, if you see
a spark jumping from the boot,
replace the plug wires.
I'm going to guess you pulled the
plug wires off when you did the header
and one of them is damaged or old
and is now leaking the high voltage spark
Offline Natebert
  • 1098
« Reply #21 on: March 28, 2005, 03:42:23 AM »
Darin,
You made it home ok?
~Nate
Proud2BCDN
« Reply #22 on: March 28, 2005, 03:49:31 AM »
Make sure all of the header bolts are torqued correctly...sounds like it could be a leak around the header flange...
« Reply #23 on: March 28, 2005, 03:56:11 AM »
Darin,
~Nate
Well I'm OK, but the trucklet
That's another story,   :'(
Offline mahimahimo
  • 377
« Reply #24 on: March 28, 2005, 04:42:23 AM »
checked the bolts they were all good it still did it ......changed the plug wires it stoped maken the noise ...thanx alot guys i appreciate it like no tom
                                    -mo
Offline mahimahimo
  • 377
« Reply #25 on: March 28, 2005, 06:59:46 AM »
i tke it back it still maken the noise just not as bad  lol im gonna have to keep investigating any other tips would be very appreciated  ....also could the head gasket possibly be faulty?
                                -mo
« Last Edit: March 28, 2005, 08:25:16 AM by mahimahimo »
  • 1456
« Reply #26 on: March 28, 2005, 12:19:27 PM »
                                    -mo
im gonna check my wires once it gets dark, and see
Offline mahimahimo
  • 377
« Reply #27 on: March 28, 2005, 01:03:58 PM »
ehhh it still did it i was talken to a friend and he said sometimes it could either be a small leake or that ticking is the engine and wit the header u can hear more of the combustion or somthin alond those lines
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #28 on: March 28, 2005, 03:09:25 PM »
                    -mo
Thats it. The gasket you put on has a sheild on it for the plug wires. the rivits that attatch it to the gasket raise the header off the head... causing a leak. Use the calmini one.
Mike
Offline mahimahimo
  • 377
« Reply #29 on: March 28, 2005, 03:30:18 PM »
yea i think i found a problem a  bolt altheway on hte back bottom under that loop really loosened up im gonna let it cool tehn test it out .... i did use the calmini gasket  though ill let u guys know what happenes
