Alternate Alternator
  • 13 Replies
  • 2402 Views
Offline CBTracker
  • 140
  • OH, you think I can't make it through?
« on: March 28, 2005, 12:55:18 PM »
So my alternator went a couple of days ago. decided 14 volts wasn't enough, and 18+ was better, so needless to say it's not just the regulator and it'll be cheaper to replace the whole thing, anyone have any suggestions? I have a light bar now, and an amplifier for my stereo, in the future I'd like to grab a winch for it, so there's alot of load on it. Does anyone know what would be a good investment, something not too expensive but that wouln't have to be replaced if I get a winch? Oh, I'll try to post pics of my new lightbar this week, good for all ye soft-toppers  :-[
96 Tracker 2dr on 215s, 2inch suslift soft top, GPS Nav, Light bar.
89 Tracker 2dr hardtop, 235s 1inchsus custom body work, push button starter
Offline Natebert
  • 1098
Re: Alternate Alternator
« Reply #1 on: March 29, 2005, 04:30:45 AM »
Running 18+ volts will burn up most light bulbs in half of the time.  They are nice and bright, but you'll be replacing them often.
~Nate
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #2 on: March 29, 2005, 04:34:36 AM »
With all those accessories, you don't need more VOLTS, you need more AMPS.  I think you can put on a GM alternator that's good for 100 amps, instead of the factory 55 or 60 or whatever it is.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline Natebert
  • 1098
« Reply #3 on: March 29, 2005, 04:35:52 AM »
Get an Optima Deep Cycle (yellow top).  It will maintain it's 12 volts over a longer draw then a high cycle battery.
~Nate
« Last Edit: March 29, 2005, 06:58:47 AM by natebert »
« Reply #4 on: March 29, 2005, 06:57:14 AM »
ya 14.7 is about max on the volt side, any more your stereo would not like it too much.
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #5 on: March 29, 2005, 07:03:10 AM »
I would run a stock alt and an optima yellow top. I run a system and a winch and I have no problems at all. Plus the Optima will last forever in a zuk. Mine has almost 400,000 miles on it between the 2 tracker its been in. I bought mine like 6 or 7 years ago.
Mike
Offline CBTracker
  • 140
« Reply #6 on: March 29, 2005, 07:37:31 AM »
I don't want to run more volts, that's my problem, the old alternator is running too many. The regulator went in the alternator causing it to put out 18+volts and therefore damaging my battery. hence me having to buy another one.  :P Sorry for the confusion. So can I purchase a 100amp alternator insted of the stock 55amp one without destroying electronics or wiring? I'd rather my truck not catch of fire. he he
« Last Edit: March 29, 2005, 07:41:22 AM by cbtracker »
Offline Natebert
  • 1098
« Reply #7 on: March 29, 2005, 07:41:42 AM »
Ah, i re-read that.
Your alternator decided that 18+ volts was what it wanted to put out...
I'd think that most stock alternators work pretty good.  Some automotive electronic places can ad more coils and get a few more amps out of it (re-winds).  I think you can get fabricate bracketry to get a GM alternator on the motor too.  (lots of amperage choices there)  but I've never done it.
Good luck
~Nate
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #8 on: March 29, 2005, 12:48:25 PM »
So an Optima Yellow Top with a stock alt works well even if you have fog lights and a bitchn audio system?
If that's the case, then replacing a battery is a hell of a lot easier then trying to put in a GM alternator.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #9 on: March 29, 2005, 03:19:44 PM »
I'm running a stock alternator with an Optima Yellow top also and it runs my system, winch and extra lights just fine...
Offline Agent Orange
  • 711
    • Trying to learn
« Reply #10 on: March 29, 2005, 03:57:31 PM »
sadly this is information i could have used a few months ago. my battery died, so i replaced it with a canadian tire economy version.  :(
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #11 on: March 29, 2005, 10:28:01 PM »
I'm running a stock alternator and an Optima yellow top too with a winch and lights but I am currrently looking at high output options at the moment as I run an auto and would just feel a bit happier knowing I had more going into the battery.
Offline JDMFUK
« Reply #12 on: March 30, 2005, 05:59:18 AM »
I just installed a premier power welder with a 160 amp alternator in a 92 sammy. I have one optima yellow and am going to get an isolator and run two optima yellows. You can get the premier alternator and regulator without the welder for about $400 I think.
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #13 on: March 30, 2005, 10:43:52 AM »
Dude, the cause of my agonies last month were supposedly the CT battery's fault that I had in there.... :( >:(
