Parking brake light
  • 3011 Views
Offline toolman21
  • 229
Parking brake light
« on: August 05, 2005, 02:45:16 PM »
Other than the switch on the parking brake handle, what else would cause the brake light on the dash to stay on?  I checked the one at the handle, and took the wire off and grounded it myself and it still stays on....
Toolman
Offline Cwkick
  • 888
Re: Parking brake light
« Reply #1 on: August 05, 2005, 02:47:55 PM »
Low brake fluid will cause the light to come on.
Cwkick
Offline SnoFalls
  • 1358
« Reply #2 on: August 05, 2005, 03:06:01 PM »
If you have ABS, then the RWAL computer will light the bulb to indicate a code can be extraced.
Offline prairie_dog
  • 234
  • 85/413 tin top
« Reply #3 on: August 05, 2005, 03:51:24 PM »
 Electrical tape will fix that in 2 min flat ( over the light ) ;D ;D
I would check the fluid level & the wiring from there first
 Steve
Offline toolman21
  • 229
« Reply #4 on: August 05, 2005, 06:23:29 PM »
I guess I should have mentioned that...It's an 89 Sidekick so no ABS, and I have bled the brakes, so I know the fluid is ok.  I have checked the parts of the wiring I can see it all seems ok, haven't traced it down...I was hoping there was something stupid I was missing.  Possible that the sensor could be bad that detects fluid level?
Looks like I might just lean towards the electrical tape.... ;D
Toolman
Offline Dihnekis
  • 398
« Reply #5 on: August 21, 2005, 10:10:54 PM »
I have the same problem. If I turn my tracker off and turn it back on it goes out.
1988 Suzuki Samurai
