Rear Lock Rite Couplers or No Couplers ????
  • 9 Replies
  • 2381 Views
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
« on: March 10, 2005, 02:18:26 PM »
Ok I've decided on a lock rite locker for the rear.
"Locker Front or Rear"
Now I notice that there are two choices for the rear locker
with Couplers and without.
Can anyone tell me the difference? ???
I looked at powertrax web site and in the diagrams it shows the couplers.
When you open the pdf file for suzuki it says one model is designed to work with stock side gears and the other replaces them.
Did I just answer my own question?
Any way I was just wondering what everyone's thoughts on this are.
Thanks Again.
Mean Green Wheeling Machine
Re: Rear Lock Rite Couplers or No Couplers ????
« Reply #1 on: March 10, 2005, 03:06:42 PM »
You won't need them, use the
good side gears you have in your diff
Offline bashzuk
  • 784
« Reply #2 on: March 10, 2005, 04:33:04 PM »
Thank You! ;D ;D ;D ;D
Offline Natebert
  • 1098
« Reply #3 on: March 11, 2005, 03:05:52 AM »
Ditto.
I'd suggest to use your existing side gears.
~Nate
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« Reply #4 on: March 11, 2005, 03:33:07 AM »
there is very good instructions with the lockright and it shows u how to determine weather or not u need to replace them. u may want to order them and return them if u don't use them. however i did not order any and used my stock ones.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
« Reply #5 on: March 11, 2005, 09:09:45 AM »
loc-rites come either for stock side gears with  coarse cogs or come with there own side gears with a finer cog that will slip if you bend an axel or housing.
Offline 90Stomper
  • 427
« Reply #6 on: March 12, 2005, 01:31:16 PM »
since i just got mine and 'bashzuk' is getting them this added question might help us both.  i got them 'no sidegears'  in the box their are their are 2 dougnuts with the square notches and pins and springs. thats it.  i read the directions over once quickly.  is that it?  or am i missing some parts.  looks pretty sparce to me for $200. :-/
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
« Reply #7 on: March 12, 2005, 03:11:06 PM »
Thats it, there might be a couple of thick looking washers with it, just take out your four spider gears (yours might have two) and put those in and check for proper clearence torque that Bad boy back together and make sure you mark the one side adjustment that you take appart so that it goes back in the same place, use some loc tite on the small bolts that you take out if you want, I would use the blue type and your down the road.
« Last Edit: March 12, 2005, 03:13:46 PM by mrfuelish »
Offline bashzuk
  • 784
« Reply #8 on: March 30, 2005, 05:09:58 PM »
Locker came today Smallest parts I have ever seen. and the smallest box. but for 175.50 with free shipping from central4wd.com I'm not complaining.
I'm hoping it doesn't take me too long to put in.
;D ;D ;D
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #9 on: March 31, 2005, 04:06:31 AM »
rrr those big washers , I forgot to put mine back in when i switched dffs, mainly due to it all falling on the floor , so im pretty good at it now as had to take it apart again,
Good luck mate nothing to it really just set your back lash and your away
Markyb (UK)
UK Vitara JLX SE
