BODY MOUNT CRUSHED
  • 18 Replies
  • 3027 Views
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: BODY MOUNT CRUSHED
« Reply #15 on: March 30, 2005, 03:51:06 PM »
Actually in every pic the square-stock pieces aren't bent or tweaked at all! The damage appears confined to the Tracker's floor and frame horns... The square lift blocks themselves are all fine!
Offline zookiemike
  • 474
  • $,reppin Michigan,$
« Reply #16 on: March 30, 2005, 06:54:00 PM »
THAT IS WHY BODY LIFTS SUCK ::). Just learn to drive with small tires or get somthing that can be lifted easy, Like a samurai. My budy had the same thing happen to him on his sidkick. He just boxed everthing in with 1/4in plate. Doesn't make me want a dam body lift. And calmini wants you to put the waight in a tracker to make it ride good. i think they need to go thrugh there kits a little better. I hate my samurai's springs: >:(
« Last Edit: March 30, 2005, 06:59:21 PM by zookiemike »
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« Reply #17 on: March 31, 2005, 12:17:32 AM »
ok i thanks for the picks. do u have anything after it was repaired. calmini bobylift sucks rocky-roads is actually quite stable. i do have a clamini body lift. and smis r much smaller inside than kicks i guess if u weigh like 200 lbs u would be fine in a sami. i wiegh 330 that is actually why a got my tracker instead of a wrangler because there is more room in a tracker. anyway i am making my own lift ti eliminate all the stablitity problem it will be weld in though. i am using 3 1/2 by 3 1/2 od to buid it out of. i will weld it to the frame and dirll holes in the top tp bolt on the rubber mounts. the pieces will be 4" long running linier with the frame that will cure part of the problem. the second part is welding angle iron on the sides of the floor braces for more suport i will also put a 3/16 piece of steel between the angel to cover the floor brace were the bolt comes down. i was thinking of removing the body lift but i have lifted the gas tank ran my exaust aboove the frame and a few other things. i think it will be easier just to keep the body lift.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #18 on: March 31, 2005, 04:12:07 AM »
loooks well nasty,,  ,, My mate jason had a simular problem his body lift shifted forward after hitting a post,  not as bad as yours,
Im glad my roll cage goes through the body works as it will stop it from moving like that . ...
Markyb (UK)
UK Vitara JLX SE
