you could pull a plug (#1), put a wad of paper
of stuff a rag into the hole, ground the coil
wire to something (off the cap) and crank
the starter until you hear the compression
pop the rag out, then turn the engine counter
clockwise and line up the mark on the pully and
timing belt cover, now hook up wires starting at #1
where the rotor is pointing and go around clockwise
And yes, the rotor needs to fit into the notch in the
distributor right or it will not run
