Tracker Solid Axle + Rear Done!!!!!
  • 48 Replies
  • 11569 Views
Offline Skunk
  • 147
  • Offroadnuts.com
    • Offroadnuts.com
« on: June 22, 2005, 11:17:55 AM »
Well here it is, my 94 Tracker.... here are the specs:
Front and rear axles out of a 82 Toyota pickup
4.10 gears
locked front and rear
leaf spring suspension front and rear
4.26:1 T-case gears
rear 4dr shaft shortened for the rear
front is a shortened 2dr rear shaft
Any questions feel free to ask.
98 SFA Explorer - D44 front, 8.8 rear both locked on 35's, Man. T-case, Warn XD9000i
94 Tracker  Toy locked axles 5.29 r/p's, toy steering, 4.24 t-case, 35" MT's, YJ leafs, warn 9500hs
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
Re: Tracker Solid Axle + Rear Done!!!!!
« Reply #1 on: June 22, 2005, 11:22:46 AM »
I'd love to see some up-close pics of how you did the front suspension. :)
Offline explosivo
  • 3157
« Reply #2 on: June 22, 2005, 11:25:53 AM »
Ditto on the pics. What did you do for the rear? Coils?
omghi2.us[/url]
Offline 92Sidekick4x4
  • 1456
« Reply #3 on: June 22, 2005, 11:39:01 AM »
well with out *more* pics  ;D
Offline Skunk
  • 147
  • Offroadnuts.com
    • Offroadnuts.com
« Reply #4 on: June 22, 2005, 12:14:42 PM »
k.... sorry....
the wheelbase is extended about 10"
Offline explosivo
  • 3157
« Reply #5 on: June 22, 2005, 12:19:01 PM »
How does it drive? Streetable?
Side pic gives me a good idea where my axle will be sitting... except I think that my springs have a touch more arch than the ones you're using, so I'll definately be taking out the body lift for 33's. :P
omghi2.us[/url]
Offline explosivo
  • 3157
« Reply #6 on: June 22, 2005, 12:20:30 PM »
Homemade steering arms? Stock steering box in the stock location? How's that setup working for you (the way you have your arms and draglink)
omghi2.us[/url]
Offline Chief
  • 678
  • Whaddya lookin at??
« Reply #7 on: June 22, 2005, 12:20:49 PM »
Looks good, but.....uh, are those long bolts spacing your steering apart? And what did you use for the hi steer arms? Just steel chunks? Those bolts will snap/bend under some good wheeling.
How's it handle w/ the (I think they're called) buggy leafs?
Need more tire!!  ;D
Edit: With your suspension that way, a trac bar in the front might be a good idea. I can see that axle walking side to side a good bit with the way you have the springs mounted.
« Last Edit: June 22, 2005, 12:22:12 PM by Chief »
Offline Skunk
  • 147
  • Offroadnuts.com
    • Offroadnuts.com
« Reply #8 on: June 22, 2005, 12:34:51 PM »
actually, had it on the street a bit and it handles great, the steering arms were made from 1" thick steel machined and with the bearing cap added.... the arms are home made, 3/4" heims, 1/4" wall tubing, and the bolts are 3/4" so they should hold up quite well.
Offline Skunk
  • 147
  • Offroadnuts.com
    • Offroadnuts.com
« Reply #9 on: June 22, 2005, 12:35:43 PM »
btw, this is a mainly offroad vehicle, I live 5 min from paragon park in PA so I dont need to drive it too far and if I did, I would trailer it.
Offline Chief
  • 678
« Reply #10 on: June 22, 2005, 02:11:13 PM »
At least lie to me and tell me you'll keep an eye on those bolts!!
Got any flexy shots?
Offline Craw4x4PH
  • 121
  • www.4x4ph.com
    • 4x4 Philippines
« Reply #11 on: June 22, 2005, 02:18:44 PM »
5 mins away from the trails?! Damn lucky ;D :P
[/url]
[/url]
Offline Skunk
  • 147
  • Offroadnuts.com
    • Offroadnuts.com
« Reply #12 on: June 22, 2005, 03:41:51 PM »
Ive been wheelin for over 10 years, I go over every inch of my truck b4 taking it out in the woods every time.
flex shots coming soon, it just left the garage today for the first time. so still workin out the bugs.
Offline Natebert
  • 1098
« Reply #13 on: June 22, 2005, 04:33:46 PM »
Very cool!
What springs did you use?
Offline Skunk
  • 147
  • Offroadnuts.com
    • Offroadnuts.com
« Reply #14 on: June 22, 2005, 04:56:56 PM »
stock fronts for the rear and 1" lift fronts for the front (superlift)
