Sammi Timming Belt replacement
  • 2454 Views
Offline 3wheelerdude
  • 70
« on: March 12, 2005, 11:43:56 AM »
Hi guys, I got my hands on a very rotted sammi, Ill get more info later as I dont know much about it yet. But what I know is that it was left sitting after the timing belt broke. My question is: does a broken belt causes engine damages on these engines??(valve clearance issue) and does anyone have a walkthrough for reinstalling a new belt and making sure its timed properly?
Thanks
Joe
2000 Mustang
1996 Sidekick
1989 Tempo
1987 F150
Offline prairie_dog
  • 234
  • 85/413 tin top
Re: Sammi Timming Belt replacement
« Reply #1 on: March 12, 2005, 06:06:21 PM »
Changed mine 5000km's ago, crank spun the grooves off the belt like a big grinder anyways there was no valve clearance issues with mine. Turn the engine to TDC #1 cyl, check to see that rotor is at # 1 position, line up the timing marks on the sprockets, install belt. This should be pretty close(should run, but not perfect)  check with timing gun. :)
Mine is set at 10 degrees BTDC,
I got my book from crappy tire, it's not really detailed but it does give you all the tork specs etc..
Anyone know how you can go before ya lose top end?
  • 70
« Reply #2 on: March 13, 2005, 11:20:54 AM »
Thank you sir, ill be giving it atry as soon as weather gets nicer and ill get back to you because im sure ill encounter more problems on the way!!! And briing some pics of the beauty too!!
2000 Mustang
1996 Sidekick
1989 Tempo
1987 F150
Offline prairie_dog
  • 234
  • 85/413 tin top
« Reply #3 on: March 13, 2005, 06:40:35 PM »
Your giving canucks a bad rap, to polite (sir) ;) ;)
The only time I hear sir around here is me trying to get out of a ticket from the officer in the unmarked car I didn't see ::)
  • 70
« Reply #4 on: April 07, 2005, 12:38:54 AM »
Anyone can gimmi a crash course on how to use a timming light?? I got one but I dont know how to use it!!!
2000 Mustang
1996 Sidekick
1989 Tempo
1987 F150
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
« Reply #5 on: April 07, 2005, 03:16:35 AM »
depends on the timing light that you own do a search on the internet for you model number of timing light.
But the basics are connect pos and neg cables to battery.
connect wire to spark plug wire number one.
Aim gun at timing marks should light up every time first cylinder fires off. get a chilton or haynes manual should explain it as well. or get both and a shop manual.
Mean Green Wheeling Machine
