Electrical Boxes Under the Dash 92 Sidekick
  • 9 Replies
  • 1965 Views
« on: April 05, 2005, 10:21:43 PM »
1992 Suzuki Sidekick JLX
So now I know where the computer is at. What is the black box against the firewall on the driver side? I can unplug it and nothing happens. It runs just fine and has no problem. I also have another box that I cannot remeber what it looks like. I'm pretty sure one is the tranny unless that is built into the ecm. So help me if one is a keyless entry and I never got any remotes when I purchased the truck used. I would be pissed since I'm sure I could have replacement remotes. I remeber checking it out back in the day and couldn't find anything. I know it would have to a after market add-on. Pictures and explinations would be nice
Also I couldn't find anything in the electrical diagram to indicate and additional black box connected to what seems to be everything. THen again I didn't find the tranny wire diagram either.
Come to think of it. I think one is power lock / window control since the sidekick is fully loaded. Except for like power seats or cruise control.
One more thing. I got a rear wiper control. One of the lights is burnt out. Little plastic gray thing with light. Nobody has it. Is this a dealer only item? Currently I only have one light and not both. One for washing and one for wiper control.
Thank You,
Josh
« Last Edit: April 05, 2005, 10:36:49 PM by ussexplorer »
Offline Uncivilized
  • 1469
    • Car Domain
Re: Electrical Boxes Under the Dash 92 Sidekick
« Reply #1 on: April 05, 2005, 11:10:19 PM »
Does the "black box" look like it's bolted in to factory location with studs off the firewall? or is just tie-wraped or taped? Do the wires travel into/with the factory harness or are they seperate with tape or split loom? -Anything written on the box?
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #2 on: April 06, 2005, 01:12:35 AM »
If it's a JLX, it came with the keyless remote security system from the factory.  Look under the hood, against the firewall, and you'll see the "speaker" that does the alarm.
Also you would have a little switch just to the left of the steering column - "up" is the "valet" position, that turns off the alarm.
The other black box should be the brake computer (you have rear wheel ABS - I can't say that I ever noticed it actually "working" though).
Don't touch the metallic blue box that gets warm when you drive, that's the flux capacitor (OK, just kidding, it doesn't get warm...)   ::)
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
« Reply #3 on: April 06, 2005, 04:12:41 PM »
Yes, it is a jlx. Please tell me your kidding about the keyless entry. (My wife loves keyless entry) Would explain it though. Um, from what I remeber it all looked factory. No name on the box but some numbers. I will have to look at them again. The one box I'm thinking of is black, and not really bolted on. But there is a clip that is clips onto. Nothing looks spliced in. Plus I don't ever remeber seeing a security light or speaker. So I really didn't think it was a security box. I'll have to look at it better during the day. All I know is I unplugged it years ago trying to sort out the problem and the vehicle ran just fine without it. Then I plugged it back in. I think the other box is for the windows. Not sure. I cannot remeber if the power key locks worked or not. So the rear is ABS? I didn't think it was since I have no ABS light in it. If just looks like a set of extra wires heading over to a extra box. To bad it wasn't a backup ecm. That would have been cool. For along time I thought it was the ecm. I know now of a few other things though. Like horn relay and such. So I know where that is and the ecm is now.
later,
Josh
« Last Edit: April 06, 2005, 04:15:00 PM by ussexplorer »
« Reply #4 on: April 06, 2005, 04:23:24 PM »
I have a JLX and I didn't get
any of that fancy stuff   :'(
I wonder if the dealer just installs
all of that add on junk in the JLX
models and charges more to the
buyer without asking first ???
I don't have power locks, I've
been in the doors and I know
they are just manual locks
Didn't get an alarm, I put one
in, but it hasen't been plugged
in for years
Offline SnoFalls
  • 1358
« Reply #5 on: April 06, 2005, 04:41:03 PM »
The black box is most likely the ABS computer. Easy way to know if you have a rear ABS is to look at the front of the rear diff and if it has wires to a plug into the third member, you got rear ABS.
« Reply #6 on: April 06, 2005, 05:45:44 PM »
well as for the alarm. I didn't they got installed until like 95. But then again that website also aid tilt steering wasn't added utnil 95. But yet my 92 has it. Also I keep forgetting to put. 16v 4 door. Since that seems to make a difference.
Well I think I found the answer. I found a  oem box on-line and it looks exactly the same. It is for Rear ABS. Strange it has rear abs. I never realized it did.
later,
Josh
« Last Edit: April 06, 2005, 06:04:42 PM by ussexplorer »
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #7 on: April 07, 2005, 02:11:46 AM »
Don't take the "rear ABS" too seriously.
My 95 4-door 16 valve JLX also has it - jam on the brakes on a gravel road, and you'll lock up all four.
Oh, and the ABS doesn't work in 4-wheel-drive.
In my opinion, it doesn't work at all, and that's my conclusion from FOUR 4-door Sidekicks.
Now the ABS on my wife's Grand Vitara works really well - we get to see it kick in all the time on ice.
Anyway, both my 95 4-door JLX's came with the factory security system (and keyless remote to open the doors).
Bob
Offline SnoFalls
  • 1358
« Reply #8 on: April 07, 2005, 03:02:54 AM »
Yea I never got the ABS to kick in whenever I tried either. I've since swapped out the rear third and the new one doesn't have the speed sensor :)
One more thing abnout the ABS rear thirds ... some lockers may be a problem to install in one (I think the mini-spool wouldn;t be a problem, but I seem to recall that ARB for example requires a non-ABS rear ...)
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #9 on: April 07, 2005, 05:07:54 AM »
Nah, that's a rumor - laugh it off.
I just left the interruptor ring out, when I put the ARB in - I can't recall if I hooked the sensor back up or not.  No worries.
Bob
