Engine Carnage Pics, Now With Bottom End Damage
  • 20 Replies
  • 8956 Views
Offline zaggy
  • 1134
Re: Engine Carnage Pics, Now With Bottom End Damage
« Reply #15 on: July 12, 2005, 10:47:40 PM »
Whats the actual stroke increase you're going for> the reason i ask is that as I recall the G13B connecting rods are shorter, same journal and pin size if I remember right, combo might work for your strok increase without custom pistons
Zag
Offline zaggy
  • 1134
« Reply #16 on: July 12, 2005, 10:50:14 PM »
Still wanna test some parts with thus engine combo change?
Zag
« Reply #17 on: July 12, 2005, 10:55:28 PM »
Won't fit 1.3 rods, the 1.3 rods are about 1" shorter,
the wrist pin is smaller, as well as the journal is also
smaller
After all the looking, and if you were to try and regrind
the crank, then the pistons would hit the counter weights
on the crank, if the rods were only slightly shorter, say 5-10mm
this might work.
The actual stroke increase is 4-5 mm which is only a 2-2.5 mm
increase in the actual location of the rod journal, if I were to
go 3mm the displacement would jump to 1788cc with a 2mm
increase in piston dia
« Reply #18 on: July 12, 2005, 10:56:54 PM »
The stroker motor is a back burner project,
I'm building the 1.6 for the 16V head first
Offline zaggy
  • 1134
« Reply #19 on: July 12, 2005, 10:58:06 PM »
Cool...that;l get ya motor'n
Zag
« Reply #20 on: July 12, 2005, 11:01:57 PM »
Zaggy, go to chat
