new 2 zuks;  simple question
  • 21 Replies
  • 3905 Views
Offline oops-sorry
  • 20
  • just call me oops
« on: April 14, 2005, 11:33:22 AM »
hey everyone, im new here and to the zuk world.  i have a couple of simple questions.  i have a 1989 sidekick with a 1.6 carbed engine and a 5 speed.  at 65 m.p.h its going about 4300 r.p.m.  is this normal?  seems kinda high to me.  would it be o.k. to drive to work at this r.p.m. everyday (30 miles each way), or will this wear out the engine really quick.  i have more questions but i will ask later.  thanks everyone
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
Re: new 2 zuks;  simple question
« Reply #1 on: April 14, 2005, 01:21:53 PM »
if that is were the factory set it then it has been driven at that rpm for as many years as it has been alive. mine is a 94 16 valve fuel injected it runs at 4300 at 80 mph.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline Cwkick
  • 888
« Reply #2 on: April 14, 2005, 01:41:53 PM »
Welcome Oops!
You could put a little taller tire on to drop your RPM's a little.    ;)
These engines are made to rev high so it shouldn't be a problem.   :D
Cwkick
Offline oops-sorry
  • 20
  • just call me oops
« Reply #3 on: April 14, 2005, 02:59:53 PM »
thanks 4 the quick replies  ;D
« Reply #4 on: April 14, 2005, 03:42:50 PM »
My 97 4dr has 235x75 tires
95 Tracker 32"tires and the 5:83
Just turn 120K miles. Gotta find the switch and shut the Check engine light off again(already replaced T-belt) ;D
NeverMind, You have a carbed 8valved.
« Last Edit: April 14, 2005, 03:54:48 PM by trickker »
Offline van7559
  • 145
  • I'll Leave Tracks All Over Your As$
« Reply #5 on: April 14, 2005, 03:49:46 PM »
The switch is behind the left speaker. Take off the panel that covers the speaker, then take out the speaker, and then if you are looking at the open hole it is just inside to the right ya can't miss it. Flip it the opposite way and you are goood ta go.
95' Kick with a 3 in. body lift and plenty more to come!
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #6 on: April 14, 2005, 03:54:54 PM »
4300 rpm is about where my 90 Tracker would run at 65 MPH with the stock tires... Seems normal to me.
Offline explosivo
  • 3157
« Reply #7 on: April 14, 2005, 11:25:36 PM »
Yeah, that's right about where mine runs with the 215/75R15's, too :)
omghi2.us[/url]
Offline oops-sorry
  • 20
  • just call me oops
« Reply #8 on: April 15, 2005, 12:21:39 AM »
you guys are great, thanx again for the quick replies and for the pictures from hotrod ;D
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #9 on: April 15, 2005, 02:18:08 AM »
And yes, you can run it ALL DAY LONG at 4300 RPM, and it'll still last for a quarter million miles, if you take good care of it.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #10 on: April 15, 2005, 02:19:42 AM »
That's way too much work!  On a 95, hust pop the trim panel under the steering column (no screws), and reach in, and to the left - you'll find the switch (I know I can in the dark, even).
Bob
Offline SnoFalls
  • 1358
« Reply #11 on: April 15, 2005, 06:56:11 AM »
FYI, here's where it is in my 91 trac ...
Offline CBTracker
  • 140
  • OH, you think I can't make it through?
« Reply #12 on: April 15, 2005, 07:31:40 AM »
DO you know where the reset switch is on the 96's
96 Tracker 2dr on 215s, 2inch suslift soft top, GPS Nav, Light bar.
89 Tracker 2dr hardtop, 235s 1inchsus custom body work, push button starter
Offline Cwkick
  • 888
« Reply #13 on: April 15, 2005, 08:04:10 AM »
96 is probably an OBD II.  You have to use an external scantool to reset it.
Cwkick
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #14 on: April 15, 2005, 08:26:53 AM »
Yup - 96 what a year for changes!  "Curved" dash instrument cluster, air bags, and OBDII ECM.  Sure enough, you need a scan tool to turn it off.  They run about $120 at Checker's Auto Parts...
Bob
