Anyone have any tips on replacing the front springs on a Calmini kit for kick? I was thinking that I might be able to just unbult the the ball joints from the bottom of the  controll arms.  Then I could just swing it down and drop the spring out.  or am I going to have the do this pain in the |removethispart|@$$ way and unbolt all the other stuff???George
If you haven;t already, ditch the sway bar.I disconnect the strut at the top, compress the arm with a jack, pull the 3 bolts from the ball joint, lower the arm, and out comes the spring.
after readen all this 2 questions .....which is the easiest way...and y is it good to get rid of the sway bar....thanx                       -mo
I personally just unbolt the 3 balljoint bolts. :-/ It is a pain to reallign but Ive done enough that Im kinda used to it.Mike
aight thanx...now i can finally get my spacers in ...hopefully tom ..how do u alighn that ball joint ...and how hard is it ...                       -mo
