how to get oil off of asphalt
  • 10 Replies
  • 3162 Views
Offline bandit86
  • 1641
  • elv8rguy
« on: April 17, 2005, 10:12:01 AM »
perferably with household chemicals
Re: how to get oil off of asphalt
« Reply #1 on: April 17, 2005, 10:21:06 AM »
A Heavy Duty Engine Degreaser would be a good start.
Just spray it on and give it a few minutes to work and hose it off.
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #2 on: April 17, 2005, 10:28:45 AM »
Laundy soap works great on concrete. Ive never tried it in asphalt.
Mike
Offline PWSX3
  • If it's a 4-wheel drive it should be off-road
« Reply #3 on: April 17, 2005, 10:39:02 AM »
I have used "Purple Power" and that worked pretty well. I think "Simple Green" would also work well.
1987 stock for now Sami for my 15 year old's first vehicle.
We Wheel with a 1994 Ford Explorer 5" Superlift, 35" tires, locked in the rear, custom tire rack, sliders, misc. stuff.
Offline jzap
  • 515
  • How difficult can it be?
« Reply #4 on: April 17, 2005, 11:19:01 AM »
I think the product is called "Oil Dry".  It comes in a bag like kitty litter (kinda looks like kitty litter too).  If you put it on while the oil is fresh and work it in with the sole of your shoe, it does a pretty good job of drying it up.
If it has had more than a day or so to soak in, it will leave a spot.  Asphalt is basically just thick oil, and oil will soften it over time.
Jim Z.
66 Apache camper
Offline bandit86
  • 1641
  • elv8rguy
« Reply #5 on: April 17, 2005, 12:34:49 PM »
oil soaks intoi asphalt, and affects its physical properties, different from concrete
Offline SnoFalls
  • 1358
« Reply #6 on: April 17, 2005, 12:37:31 PM »
plain old kitty litter will absorb oil (not the "clumping litter, the cheapo "non-clumping" is best) ...
As other said tho, asphault will also "absorb" (and disolves in) oil, so it'll never all come out.
« Reply #7 on: April 17, 2005, 02:54:19 PM »
Detergents, not degreasers are
best, degreasers have solvents
that can harm the asphant worse
than the oil you are trying to lift off
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #8 on: April 17, 2005, 04:26:52 PM »
TIDE ::)
« Reply #9 on: April 17, 2005, 07:15:06 PM »
For about 30k the DEQ will come and fix it for you.  ;D
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #10 on: April 18, 2005, 03:56:32 AM »
I would start with plain old sawdust, to soak up as much oil as possible.  Then the detergent.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
