toyota axle gears
  • 15 Replies
  • 2460 Views
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
toyota axle gears
« on: April 10, 2005, 01:49:02 PM »
what is the largest size R&P i should go with in a 85 toy truck front axle. i have heard rumor about the larger sizes compromising the strenght of the pinion shaft due to the fact of it small size.
« Last Edit: April 10, 2005, 02:16:19 PM by tracker8wr »
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline mesjr2004
  • 422
Re: toyota axle gears
« Reply #1 on: April 10, 2005, 02:56:01 PM »
i think unless your running a v8 dont worry about it in a 2500lb tracker .imo
Offline tracker8wr
  • 568
    • my home page
« Reply #2 on: April 10, 2005, 03:28:22 PM »
i heard this from a guy who runs a flatbed yota pickup with a four banger on 38.5" swampers.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline zeb
  • 10
« Reply #3 on: April 10, 2005, 03:59:32 PM »
how big of tires are you going to be running. I have a zuk with 35's but going to 38's soon and running 5.71. also had a toy pickup daily driver for 4 years 35's and ran 5.71 no problems with pinion shafts.
Offline blyota91
  • 71
« Reply #4 on: April 10, 2005, 11:28:17 PM »
I've always heard 5.71 is pushing it due to the strength of the pinion gear, most guys don't recommend anything above 5.29's.
Andrew
1988 Samurai 5inch SPOA and 32X9.5 TSL's  Giggity Giggity
Offline tracker8wr
  • 568
    • my home page
« Reply #5 on: April 11, 2005, 12:12:17 AM »
blyota that is the same thing i was told. for now i am going to run 37" irocs biasply. i had orginaly said 35 to 37" but i may swap to 40s later and tube it out next year so my duaghter will have something safe to drive.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline Natebert
  • 1098
« Reply #6 on: April 11, 2005, 06:50:55 AM »
The land crusier guys don't usually  recommend anything above 4.88s.
~Nate
Offline mesjr2004
  • 422
« Reply #7 on: April 11, 2005, 10:14:31 AM »
has anyone done a side by side comparison with the tracker 5.13 and the yota 5.71 . ive had them both apart and bont rember any alarming differences in the size of the pinion shaft. i am running 5.71s in mt track and breaking them is the farthest thing from my mind . have any of you driven a tracker with 34"-35"tires with a stock motor ? break the pinion shaft  ya rite ,maybe if you stucket on the revlimiter put in 2nd gear and sidesteped the clutch maybe , but probably not. these trackicks weigh probably 1000lbs less than a toy truck,and have fewer ponies . but i may be wrong
Offline Natebert
  • 1098
« Reply #8 on: April 12, 2005, 02:18:44 AM »
FYI
We have a Sammy owner here in town on 35 baja claws, equiped with a 1.6 8v with the weber carb and he brakes his 4:10's all the time.  Granted he's the hardest on stuff of any guy I know, but he still brakes them mini-truck axles and gears in a sammy, with no crawler gears in the t-case.  (it's always the either the axles or pinion gear which gives out.)
Our truck-let (if I can still say that anymore) weights in just about as much as a fullsize land cruiser.  (~4800lbs loaded with camping gear.)
With the dual t-cases, one with 4.24 and one with 2.2 gears, I think I've got enough torque to brake stuff handily.  Which is why I upgraded to larger axles to begin with, I'd hate to think that I'd be taking steps backwards by 'upgrading' gears to something weaker.
But then again, to each their own.
~Nate
« Last Edit: April 12, 2005, 02:28:37 AM by natebert »
Offline chet
  • 556
  • Zuki time!
« Reply #9 on: April 12, 2005, 06:19:36 AM »
I had a 5500 lb toy on 4.37's and 37's and never broke a ring and pinion. I have numerous club members with toys on 5.29's and they rarely have problems and most of them have 37" tires and dual tcases. I would not go to the 5.71's they are pretty small!
Offline zukatude
« Reply #10 on: April 12, 2005, 09:13:01 AM »
How are you getting a tracker with toy axles and decent sized (33"+) tires down to 2500 lbs?
Remove all glass/fenders/doors?
Incidentally, I put 5.29 gears into my toys.  The 5.29 pinion is TINY compared to the stock 4.10.  I personally wouldn't go any smaller than 5.29 especially if you have deep crawler gears.
87 Sammi: YJ SPOA SR on locked 5.29 toys, 35" MTR, 6.5 tcase, Warn M8k
Offline tracker8wr
  • 568
    • my home page
« Reply #11 on: April 12, 2005, 09:14:57 AM »
i am actually planning on 4.88 gears and a sammi t-case reduction to give me a good running gear ratio. thanks for all the input.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline mesjr2004
  • 422
« Reply #12 on: April 12, 2005, 11:17:14 AM »
i read somewear the curb weight was under 2500lbs
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #13 on: April 12, 2005, 12:50:08 PM »
I was told stock curb weight empty was 2150. Ive never checked though.
Mike
Offline mesjr2004
  • 422
« Reply #14 on: April 12, 2005, 01:32:17 PM »
Mike
theirs a grain elivator with scales about 7 miles from my house i may have to go weigh the tracker one of these days.
