Sidekick engine problems.....
  • 1524 Views
Offline skandy32
  • 93
  • Zukiworld Rocks!
    • Andy Colver Photography
« on: April 22, 2005, 04:30:06 AM »
i recently brought a suzuki vitara (im in the UK, so thats a sidekick? i think to you?), the day i got it, i ragged it a little, you know testing the speed and offroad ability an all! anyway, since then it has developed a leak, an oil leak. Which with my limited mechanical ability have worked out to be the oil pump (which pumps oil to the back axle). No problem i thought, keep on driving, and top it up more often than usual. even though there was now a nice clunky noise when i reved it so high (which i just asumed was the lack of oil in the engine!?)
Then the other day, i started it up, to see a nice pretty oil fountain immerge underneath the engine on my dads drive... not good!!
it was the oil filter, didnt seem to be on properly. So, i brought a new one, replaced it, and brought new oil to fill it all up so the dipstick reading was ok.
Should be ok now yeah?? no, now, the original leak is still there, (which i thought the dodgy oil filter would have fixed!) and i get this really bad clunky noise when i rev it so high, it shakes the whole jeep!! and doesnt sound very healthy. Just today i started it up, works / sounds ok till it is reved and i get this clunky engine noise, and i just noticed when this happens a lot of white smoke comes out of the exhaust.....!?
so anybody know the answer?? anyone that could point me in the right direction of help?
cheers
andy
« Last Edit: April 22, 2005, 04:31:38 AM by skandy32 »
UK Vitara - 2" spring/shock spacers, 3" calmini body lift, 32x11.5x15" BFG MTs, rear half calmini exhaust/no cat, full Alpine ICE
http://www.andycolver.co.uk
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
Re: Sidekick engine problems.....
« Reply #1 on: April 22, 2005, 06:43:42 AM »
is ur oil look like milk when u checked. if it looks like milk head gasket. if the oil is not milky bad piston ring or bad valve. the clunking sound man anything inside the motor bad bearing, valve not functioning properly, pully misaligned, and any number of things could be lose. oh the oil pump does not pump oil to the rear axle it only pumps it back to the top of the engine. for ur leeky filter check and make shure the gasket surface of the motor is smooth and even other than that good luck.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline skandy32
  • 93
  • Zukiworld Rocks!
« Reply #2 on: April 22, 2005, 10:54:07 AM »
no, not milky, more dark chocolately look to it.
anyone else able to help?
thanks so far
andy
« Reply #3 on: April 22, 2005, 07:06:06 PM »
Rod bearings, need to rebuild the engine
before you destroy the crank or the block
