Cv shaft troubles again.....
  • 20 Replies
  • 3138 Views
Offline Speedracer7c
  • 2210
« on: April 16, 2005, 12:37:39 PM »
Well put in my other cv shaft today, The drivers side shaft. and It basically was over extended as soon as I put it in. So i had to loosen the bolts just to put the snap ring in. I guess I'll just get a spacer machined or something. Is that what everyone else is doing. I don't know why this is happening all the time now. And I wheeled with the stock one in there for a year.
  • 2210
Re: Cv shaft troubles again.....
« Reply #1 on: April 17, 2005, 02:08:01 AM »
anyone......? Bueller Bueller...... ???
« Reply #2 on: April 17, 2005, 03:38:49 AM »
It all goes back to your port 47 troubles man.
  • 2210
« Reply #3 on: April 17, 2005, 04:08:04 AM »
Thanks zook....your such a big help.  :P
« Reply #4 on: April 17, 2005, 04:42:19 AM »
Did you put in spring spacers? that will do it.
And make sutre the Passenger one is snapped in all the way.
  • 2210
« Reply #5 on: April 17, 2005, 05:49:43 AM »
YEah but if i make a spacer for the cv shaft will it solve the problems or will it not?
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #6 on: April 17, 2005, 06:02:13 AM »
Do you have an Anvil? Is it widened?
Mike
Offline Setheron
  • Mud For Blood Rocks For Brains
« Reply #7 on: April 17, 2005, 06:52:28 AM »
I'm thinking that it should fix your problem but i don't know your truck? is it lifted or did you just put it in a ditch or hit a stump?
« Reply #8 on: April 17, 2005, 09:43:50 AM »
#p
  • 2210
« Reply #9 on: April 17, 2005, 11:11:02 AM »
Mike
Nope and nope.  :(
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #10 on: April 18, 2005, 05:42:02 AM »
You're running the 2 inch Calmini lift, which drops the diff, right?  You should NOT need a longer CV axle!
I would suspect that something else has caused the problem.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
  • 2210
« Reply #11 on: April 18, 2005, 10:53:30 AM »
Here you can see how badly the cv shaft was over extended just sitting there.
Which resulted in this after wheelin.
« Last Edit: April 18, 2005, 10:54:40 AM by speedracer7c »
Offline explosivo
  • 3157
« Reply #12 on: April 18, 2005, 10:37:04 PM »
Had the exact same problem. A large part of the reason I've got a set of 'Cruiser axles sitting in the garage to go under the Tracker ;)
omghi2.us[/url]
« Reply #13 on: April 19, 2005, 01:52:08 AM »
Give us some details on how you front end is lifted. It appears to be tha Calmini 2" suspension lift, with the diff drop brackets in place. Unless it was a screwed up rebuild on the CV, or you have modified the front end or lift, that should not happen. :-/
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #14 on: April 19, 2005, 02:19:32 AM »
Are you saying that you put a spacer in on top of the larger front coil springs I sent you?
« Last Edit: April 19, 2005, 02:20:14 AM by hcgalvin »
Heather Galvin
