anyone cut their firewall to fit bigger tyres?
  • 17 Replies
  • 3443 Views
Offline Natebert
  • 1098
Re: anyone cut their firewall to fit bigger tyres?
« Reply #15 on: July 04, 2005, 04:33:30 AM »
Cut and weld
cut and weld
cut and weld
Don't forget these;
And paint
« Last Edit: July 04, 2005, 04:36:07 AM by natebert »
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #16 on: July 04, 2005, 11:22:25 PM »
Here's the problem.
I don't give a f*** if it looks like shit!!!!!!!  8)
I need to fill a couple small holes, and water still leaks in there, but that's why I took the carpet out and have body plugs for!
I didn't say "look" I said "work", silicone will pull away and leak and cause rot. IMO
« Reply #17 on: July 04, 2005, 11:32:21 PM »
Sorry if this is a Hi-Jack, but I posted a sort of similar question before with not much response...
Zig, what did you used to cut your fenders, that looks really good.  Do you think a 3" BL and trimming fenders like yours would help clear 31's ?
I used a cut-off wheel and a sawsall (sawsall  for the majority and the wheel to clean it up) then  I used the same weapons to cut out the relpacement sheet metal and then cleaned it up with a bench grinder (after bending it to shape)
