gotta noise
  • 13 Replies
  • 2983 Views
Offline bus_driver
  • 479
  • the voices tell me different things
gotta noise
« on: April 25, 2005, 07:44:35 AM »
when I use the left indicator the indicator does not go on but there is a buzzing noise....I was thinking bad relay..  any other thoughts?
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline Setheron
  • Mud For Blood Rocks For Brains
Re: gotta noise
« Reply #1 on: April 25, 2005, 07:45:56 AM »
try replacing your 4 way flasher
Offline bus_driver
  • 479
Re: gotta noise
« Reply #2 on: April 25, 2005, 07:49:35 AM »
you mean the relay?
92 2dr soft top
235/75/15
2 inch lift
custom mud
Offline takai
  • 907
Re: gotta noise
« Reply #3 on: April 25, 2005, 09:59:44 AM »
Sounds like the relay to me. I would replace it.
'Cause, I am to misbehave.
Offline biker
  • 730
  • It's a sickness I tell ya
Re: gotta noise
« Reply #4 on: April 25, 2005, 04:11:22 PM »
I have the exact same noise and it is caused by a poor contact point in the signal light switch which in turn causes the relay to chatter or buzz. Next time you turn on the signal try just wiggling or lifting the lever ever so slightly
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline jglass
Re: gotta noise
« Reply #5 on: November 04, 2010, 07:53:11 PM »
I know this is old, but I have an 87 sami doing the exact same thing. It works perfectly for the left side, but it just buzzes when I try to make the right side blink. I'm gonna try looking at the switch, I'm just curious what fixed the problem on yours.
Re: gotta noise
« Reply #6 on: November 05, 2010, 12:53:41 PM »
I had the same problem on my SJ-410, the issue was a bad ground at the lights.
Re: gotta noise
« Reply #7 on: November 06, 2010, 07:12:40 PM »
It's the bulb or the flasher (relay) I seriously doubt it's the switch in the steering column
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: gotta noise
« Reply #8 on: November 08, 2010, 04:36:47 AM »
I had to replace the switch in the steering column, on the Gnewt, for just that problem.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Re: gotta noise
« Reply #9 on: November 08, 2010, 08:08:30 AM »
Offline tipover
  • 422
Re: gotta noise
« Reply #10 on: November 08, 2010, 06:27:19 PM »
ditto on my sidekick and sammy.  tried to fix one on the sammy by cleaning the contacts.  hard to get in there... ended up finding one from a friend.
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
Re: gotta noise
« Reply #11 on: November 09, 2010, 04:22:26 AM »
Man, talk about resurrection, this thread started over 5 years ago!
Offline idaholwb
  • 772
Re: gotta noise
« Reply #12 on: December 07, 2010, 09:49:55 PM »
Get some good electronic parts cleaning spray and take the cover off your steering wheel and column covers and thoroughly clean the whole switch assembly. Use some good quality dielectric grease to lube all the contact points and pivots when you are done. Put it all back together with new flashers for the turn signals and hazards and that should fix the entire problem. If it doesn't, then you need a new combo switch...
97 Sport
265/70-16s
2" lift
2.0 swap
Re: gotta noise
« Reply #13 on: December 08, 2010, 04:58:38 AM »
or a new truck  >:D
