Black RTV or should I wait for the gasket
  • 3105 Views
Offline zutefisk
  • 124
  • yumpin yiminy yee viss
« on: April 23, 2005, 06:16:08 AM »
Picked up a used GRS II tcase. It's leaking along the gasket where the case halves mate up. It looks like the gasket got screwed up in one spot when it was installed.
The question, Black RTV now, or wait for a gasket to ship and lose a weekend of 4.89 to 1 wheeling?
87 Samurai
Offline takai
  • 907
Re: Black RTV or should I wait for the gasket
« Reply #1 on: April 23, 2005, 06:52:49 AM »
I hate to say it. But, I would wait.  :P
'Cause, I am to misbehave.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #2 on: April 23, 2005, 07:39:31 AM »
If you're up and running without that case and are just adding it for the lower gears, I would wait for the gasket. Now if you're tore apart and waiting without any ride at all, I would RTV it, but only after realizing that I would be pulling the case again once the gasket arrives... Basically by using the RTV, you're installing the case twice...
« Reply #3 on: April 23, 2005, 08:05:28 AM »
Ultra Gray Silicone will be a permanent
fix, keep the gasket in a safe place for
next time you need it
« Reply #4 on: April 23, 2005, 08:38:51 AM »
I haven't got an FSM to hand. Would leaving out the gasket mess up any of the clearances?
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« Reply #5 on: April 23, 2005, 11:14:14 AM »
is th gasket paper. if it is the silcon will work fine and will fix it for good.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline Natebert
  • 1098
« Reply #6 on: April 24, 2005, 10:15:27 AM »
Yup, make sure the mating surface is good and clean, free of grease, etc.
~Nate
Offline xamtex
  • 72
« Reply #7 on: April 25, 2005, 08:01:55 AM »
the thickness of the gasket makes up the tolerences for the thrusts.you need a gasket!!!!!!!!!!!!!!!!!!!!!!!!!
god must love crazy people,he made so many of them!!!
Offline Natebert
  • 1098
« Reply #8 on: April 26, 2005, 04:15:41 AM »
The paper gaskets I pulled out of my Sammy T-case didn't seem that thick.  I can't imagine that they provide that much additional thickness to allow for space next to the thurst washers.
~Nate
Maybe this would be a good time to call Hawk, or TrailTough.
