So the head and it's parts are all cleaned up waiting for the machine shop....lets go to the short block
  We are going to start by marking everything...
- The main bearing caps are marked from the factory and
 even have little arrows so you know where they go
-  The rods have the nice little arrows but nothing else
 so using a small sharp punch and hammer we need to
mark the caps 1 thru 4 from the front of the engine.
Then a mark on the rod and the cap on the same side
so you know to match tem up....fool proof
- Now we measure the side clearance on the rods using
 a feeler guage
- And the same for the crank end play
-  Before removing the pistons and rods, plastiguage
 the bearings and record the clearances
-  Now check the cylinder bores for any appiciable ridge,
 if there is any it MUST be removed with a ridge reamer
 before trying to remove the pistons. Now Suzuki
 bores are really good and it is rare that there has
 been aridge I've needed to remove
-  Now following your manual remove the pistons and
 rods, Reassemble correctly as soon as they are out.
-  Now remove the rings and do a quick clean up on the
 pistons so we can check piston clearance.
-  Using a feeler guage check 3 or 4 places around the
 piston in the bore. Like the picture.
-  Now your can remove the caps and plastiguage the
 bearings to check clearances, record them and clean it
 up, Now remove the oil pump and finally remove the
 crank when done it shop be nice and clean, then  ÂÂ
 spray with WD40 or similar
-  All the surfaces should be nice and smooth no divots
 or lines. If there are any it's crank turning time.
- Now go back and look at the bearings, they should
 look like new (see mains on right) not scratched and
 scuffed (rod bearing on left)
Now you follow the manual and dissaaemble the rest, all the while saving all those nuts/bolts etc in the carefully marked containers.
  When done you should have a nice clean bare block with main caps, pistons and rods set aside and everything clearly labeled and clean.
  Now take you meassurements and compare against the clearances in the manual. This will determine if you need a rebore, crank turned etc, and give the machine shop a guide as to what specs they need to go to.
Next the parts list.
Zag
