Lift idea?
  • 39 Replies
  • 6703 Views
Offline madvitara
  • 45
  • Mud i love it
Re: Lift idea?
« Reply #30 on: April 27, 2005, 09:31:21 AM »
You can't fit front spacers on the top of the struts longer  than about 40mm (1'5/8) anymore than that and the CV joints will bind at full drop, I made brackets to drop the front diff carrier by if i remember 30mm (1'1/4) and have fitted 2" spacers on top of the struts. No problems with the CV's but the chamber is a little out, the zuk's a little twitchy at 70MPH but nothing serious
On the rear you will need a spacer between the diff and the top link to stop the joint getting damaged on full drop.
Offline Jookycola
  • 372
Re: Lift idea?
« Reply #31 on: April 27, 2005, 05:56:27 PM »
no i believe deldana is still around i had the link about a week ago and it still worked.
  [/url]
Offline bus_driver
  • 479
  • the voices tell me different things
Re: Lift idea?
« Reply #32 on: April 27, 2005, 07:16:45 PM »
can someone please comfirm the use of TJ front coils on all for corners of the 92 2 dr kick....if this is true then I can get some pretty fast and how much will the lift be on the kick 2"?
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline the_maplebar
  • 466
Re: Lift idea?
« Reply #33 on: April 28, 2005, 01:27:24 AM »
Is [link]www.deldana.com.br[/link] the right link?  I still can't get there.
Re: Lift idea?
« Reply #34 on: April 28, 2005, 08:42:25 AM »
It was the right link it used to link to the RC4x4 site
Offline 1bigtracker
  • 3409
Re: Lift idea?
« Reply #35 on: April 28, 2005, 08:47:03 AM »
i ahve never heard of useing TJ's in front but i have heard of useing them in the rear.
http://www.granitepath.com/friends/kd7hcg/pictures/springs/index.htm
stu
« Last Edit: April 28, 2005, 09:06:49 AM by 1bigtracker »
Offline bus_driver
  • 479
Re: Lift idea?
« Reply #36 on: April 28, 2005, 06:44:06 PM »
I am looking at just doin a 2" and if there are jeep springs that work than I can get from my friends or any other manufacturer that has a spring that will work.
92 2dr soft top
235/75/15
2 inch lift
custom mud
Re: Lift idea?
« Reply #37 on: April 29, 2005, 12:00:01 AM »
If they work OK in the front then they will be far too stiff in the rear.
Offline 1bigtracker
  • 3409
Re: Lift idea?
« Reply #38 on: April 29, 2005, 04:30:54 AM »
no i said they work in THE REAR.  they are too weak for up front.  i think you just got what i said confused. ;)
stu
Re: Lift idea?
« Reply #39 on: April 29, 2005, 05:37:48 AM »
stu
So you did, my mistake  :-[ Thats kind of what I meant though they will only work at one end or the other not both ends. It made sense to me at the time, lol.
Its not easy to get an idea of the comparative spring rates from those pics. There are a lot less windings than the Calmini springs but the wire gauge looks similar and they are a larger diameter so the wire length might be similar. It does say it rides like a tank though?
« Last Edit: April 29, 2005, 05:45:01 AM by Rhinoman »
