i'm seriously considering putting a lock right in the front diff.
I don't think you will be disappointed.
can people share their experience(s) please. if i do go ahead, i will limit/shorten the front end droop about 1" or 2" to try and save the cv's.
probably a good idea and I'm thinking of the same.
how is it with a lock right in the front diff? will it be the same as having one in the back? i have one in the back, and it carries on a bit, but i dont usually care.
I only heard mine while decending a steep twisty trail. Not one noise going up or under power. My understanding is under power, it "locks up" and will only ratchet when "undriven" (i.e. decellerating/steady speed).
what problems do people have with a lock right in the front?
None for me yet (but I've only been wheeling on it once)
can i safely run one in the alloy diff? i dont do a lot of rock work, high grip surface work, so maybe it may be ok.
Time will tell. One thing is that I don't have to be as heavy footed now, so I'm hoping that will offset the added stresses. Without the locker, I found my self having to "pop" over some obstacles that I can just crawl over now.
i also dont mind getting out to unlock and lock the hubs if you even have to do that. will it be ok with hubs locked and transfer in 2wd. (thinking it will be unlocked as the drive shaft doesnt drive the pinion pin)
I think hubs locked but in 2wd you would hear it pop (undriven, it'll unlock). It's made to unlock so it shouldn't hurt it (but I wouldn't run like that all the time).
I'm still running the auto hubs that came with my trac.
i know steering will be affected, but is it that bad?
I didn't find steering any harder than when I ran without it. I also have power steering
The mini-spool I have in the back is what really "pushes" me straight.
also, the lock right to fit is a sierra one, in a sierra centre, but i cant remember anything about a retaining sleeve so that the pins do not fall out. or do i use the original centre?
I had Brent at TrailTough make me one.
Essentially, you take a kick/trac/vit third. In that you put a sami/sierra carrier that has been machined larger to accept the RH side CV shaft, install the locker, setup the ring gear. Others would be better at the details (since I didn't actually do it).
I figured it was worth having someone who has done it before cook one up for me (and the machining+labor+parts charged wasn't excessive).
