In need of help!
  • 1904 Views
Offline luvcows
In need of help!
« on: May 01, 2005, 01:43:21 PM »
Hello,
My problem is with my wifes 2001 Vitara with a 2.0. The problem started with the heater core. It started to leak so I changed it out and within 3 days the new one started to leak. So until I can get the 2nd heater core replaced we are just bypassing it. But today I discoverd that the radiator is leaking. My question is am I missing something, what could be causing these things to spring leaks? Any advice would be great.
2 wheel drive Zuk's are cool too!
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
Re: In need of help!
« Reply #1 on: May 01, 2005, 01:50:05 PM »
too much pressure in the lines. just a thought
Mean Green Wheeling Machine
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #2 on: May 01, 2005, 03:06:26 PM »
I wonder if you have a headgasket problem or something allong that line. I wonder if you could do a pressure test and see if it dramaticly rises. Id get that checked asap before you wreck anything else.
Mike
Offline i2w
  • 8
« Reply #3 on: May 01, 2005, 05:23:47 PM »
Had anything been done to the vehicle just before the problems?  I wonder if something corrosive got into the water?   Possible sources:  adding liquid, adding miracle item to cooling, having radiator system flushed by commercial operation (they never get all the cleaner out and it is very corrosive) using a flush and not getting it all out (you must flush with clean water a whole lot more than the instructions)  using water only without at least 50 percent good antifreeze(especially if you use "hungry" water such as distilled or ozmose)  If you had a repair shop do the work, don't let them work on it again.
86 stock samurai
Offline Setheron
  • Mud For Blood Rocks For Brains
« Reply #4 on: May 01, 2005, 05:46:54 PM »
When antifreeze breaks down over time it turns to an acid that eats the hoses and aluminuim so i would change all the hoses thermostat and flush the system as for the 2nd heater core just make sure you don't bend the inlet and out let pipes.
« Last Edit: May 01, 2005, 05:47:11 PM by Setheron »
« Reply #5 on: May 01, 2005, 06:47:53 PM »
If it's not the head gasket put a cup of baking soda in the radiator that should kill the acid, I run clr in mine for a day and then the baking soda, cleans things real good, the next day I flush real good then add antifreeze.  ohh ya change out your thermostat and your cap just incase your oil canning your rad with it.(open close open close)
« Last Edit: May 01, 2005, 06:51:17 PM by mrfuelish »
