1.3 to 1.6 conversion
  • 4120 Views
Offline Fahrntech
  • 8
« on: May 01, 2005, 12:01:49 PM »
I was wondering what I needed to do to swap in a 1.6 fuel injection to a 1.3 carb.
I figure I'm going to need a 1.3 sami efi harness and to simplify things, I'm buying a conversion kit that comes with a fuel pump.
What all do I need from the 1.6? I think I need all the intake stuff ? I know  I need the starter and alternator, what about the puleys. Can I use my existing ones or should I use the 1.6's.
What else do I need? Do I need the harness for the 1.6 As well, or not.
Also, what is it going to cost since I don't have unlimited funds.
Any help is much appreciated, thanks for everything.
Offline takai
  • 907
Re: 1.3 to 1.6 conversion
« Reply #1 on: May 01, 2005, 12:21:40 PM »
You will need the 1.6 harness and the pulleys, the 1.3 intake won't fit the 1.6 head neither will your exhaust fot that matter. A complete kit from Hawk is around 2K (including the motor) this presumes that they get your core. Thats my .02. Best of luck.
'Cause, I am to misbehave.
Offline rkteckt
  • 214
« Reply #2 on: May 01, 2005, 02:16:20 PM »
there is an extensive discussion of this in a thread called engine swap thread
1991 samurai , Mall Crawler, neon green, YJ lift, Wifes vanity plates.
1988.5 tintop too many mods to list. The work samurai.
2005 Avalanche Z71
2003 Matrix XRS
1993 sidekick 4dr 2wd donor thats too nice to destroy yet. 1992 Toyo Pup POS
Offline Fahrntech
  • 8
« Reply #3 on: May 01, 2005, 03:18:14 PM »
I just want to make sure we're on the same page here, I was talking about an 8v swap not a 16v swap. I know they're two very different animals.
Offline real_red_wagon
  • 226
  • Make It Hert!!!
« Reply #4 on: May 02, 2005, 02:53:41 AM »
 Ã‚ all the 1.3 stuff will work on an 8 valve 1.6 thats what my brother runs. 1.3 sammi tbi with 1.3 computer the header from the old 1.3  all you need is the adapter for the trans and motormounts if you could get a tank from a '91 and up sammi with the pump in it your fuel problems are easily solved. use the clutch and flywheel from the 1.3. like I said my brother runs this setup and its way more power than A 1.3 and runs very well likewise all the 1.6 tbi stuff will fit on a 1.3 I have a 1.6tbi and manifold and computer if you need anything let me know
ohh almost forgot your rig needs to be lifted for oil pan clearance or you need a different oil pan :-/
« Last Edit: May 02, 2005, 03:07:08 AM by Real_Red_Wagon »
At Lakeview Motorsports, were wasting your time already!
Offline zuksofhazzard
  • 503
  • them darn Zuk boys
    • MOAB PICS
« Reply #5 on: May 02, 2005, 03:41:49 AM »
If you are going from a 1.3 carb'd vehicle, to a engine swap of 1.6 throttle body efi. I would go ahead and use the EFI from the 1.6 setup.
You are already adding to the vehicle. Add the correct EFI from the engine. It will be one less thing to locate on your parts round-up.
I would try and get a complete vehicle and part it out.
Who knows, maybe you will come across a deal on the 16 valve.
For what it's worth - If you are going to do an engine swap and add to your vehicle, I would go with the 16 valve.
I think both swaps, 8 valve and 16 valve, are similar in work. You will have a little bit more wiring with the 16 valve, but it isn't bad at all. Either engine will be an improvement to your vehicles driveability, and both engines are a great upgrade. I just think if you are going to do a swap, do you want to gain 20hp, or do you want to gain 40hp. With both you will get EFI.
As mentioned, refer to the thread titled something like engine swap thread. Some of the questions you are asking have been kinda answered, and there is a link to aftermarket4x4's site. Sean has a great writeup on the 16 valve install. Read it a couple of times and you will understand all aspects of the swap. The basic install for the 16 valve and the 8 valve are the same. It is just the wiring that is a little different.
I have seen people sell the 8 valve for a 16 valve swap. So, keep you eyes peeled for someone moving up. Maybe you could get a smokin' deal.
I really like both engines, heck I even have both engines in different vehicles. But, I really would skip the 8 valve and go with the 16.
Good luck, keep us posted on your swap.
