SAS Tracker steering box question
  • 2653 Views
Offline Skunk
  • 147
  • Offroadnuts.com
    • Offroadnuts.com
« on: April 29, 2005, 12:54:23 PM »
I know some people used toy boxes for steering, but what I want to know is why not use the tracker power steering box? is there something wrong with using it? is there a particular reason to not use it? what are the down sides to using the stock box?
thanx
98 SFA Explorer - D44 front, 8.8 rear both locked on 35's, Man. T-case, Warn XD9000i
94 Tracker  Toy locked axles 5.29 r/p's, toy steering, 4.24 t-case, 35" MT's, YJ leafs, warn 9500hs
Offline hcgalvin
  • 1695
    • Granite Path
Re: SAS Tracker steering box question
« Reply #1 on: April 30, 2005, 04:46:43 AM »
We're using the stock box.
It's performing fine. No complaints from it. And we've got no complaints with it.
Heather Galvin
Offline Skunk
  • 147
  • Offroadnuts.com
    • Offroadnuts.com
« Reply #2 on: April 30, 2005, 05:01:05 AM »
Good to hear, now do you think there would be a problem with drilling the stock pitman arm out for 3/4" heims? or is there anything else that has to be done to it to be used with a solid axle? yeah.. one more thing, what about that wannabe stopper on the frame.... is that important for the SAS? Im guessing thats there for the IFS only.
Thanx 4 your help
Chris
Offline mesjr2004
  • 422
« Reply #3 on: May 01, 2005, 12:21:40 PM »
the toy box goes on the outside of the frame wich makes the draglink longer and will also relieve some angles , and it is a little bigger .
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #4 on: May 01, 2005, 03:49:04 PM »
Some complain about the Kick box not coping long term with really big rubber but I have also heard that rigging up a cooler for the power steering helps fix this.
« Last Edit: May 01, 2005, 03:50:08 PM by cj »
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #5 on: May 02, 2005, 04:10:02 AM »
Thanx 4 your help
Chris
Not sure about drilling out the pitman arm, we left ours as is, and just stuck a sidekick ball joint on the end of our FJ80 draglink.
We left the stopper on the frame, and we used that in conjunction with the stoppers on the birfields.
Not sure about taking them off.. you might want to call Sky at Sky manuf. Or Hawk.
Heather
« Last Edit: May 02, 2005, 04:10:44 AM by hcgalvin »
Heather Galvin
