How many spline?
  • 9 Replies
  • 2072 Views
Offline wolf66
  • 193
How many spline?
« on: May 02, 2005, 05:06:03 AM »
I am getting ready to re-gear to 5.12's from 4.62's in my 1996 X90..............I thought the fronts were 26 spline for some reason, the guy who wants to sell em to me says:
"The front spline count of a 1996 model should be 22 spline and 1997 and later are 26 spline."
Does that sound right?  So the '96 X90 would have one size and the '97/'98 had another?
Anybody know for sure?
Only answer I have gotten so far was:
"Not necessarily.  The X-90s were all built in Kosai, Japan, not in North America, so they could have got the change earlier, or not at all."
AHHHHHHH!!!
'96 Suzuki X90-4" lift-snorkle-30x9.5's on 8x15 wheels-5.12 gears-winch-added rear seat-DT header-PioneerMP3-CB-GPS-roof rack-rear mounted full size spare
Re: How many spline?
« Reply #1 on: May 02, 2005, 05:11:40 AM »
Wolf,
They did change in the Tracker/Kicks around that time. I would suggest just pulling your passenger side 1/2 shaft and counting the splines. Then you will know for sure what you have.
I'm assuming from your wording that you are buying the complete 3rd members instead of a R&P set.
Offline zuksofhazzard
  • 503
  • them darn Zuk boys
    • MOAB PICS
« Reply #2 on: May 02, 2005, 05:16:18 AM »
I have both F/R thirds from a 96 tracker lsi, 5 speed. I think they are 26 spline. My uncle tried using the CV's in his 91 and they didn't work. I'll double check my parts too. (which happen to be for sale.....) ;)
Offline 1bigtracker
  • 3409
« Reply #3 on: May 02, 2005, 07:26:38 AM »
we put all the 26 spilne stuff in andrew's tracker and  put the front end parts next to each other and there was a slight difference in the size of the shaft,  just so everyone knows.
stu
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #4 on: May 02, 2005, 07:54:49 AM »
22 spline through 1995, 26 spline 1996 and newer.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline SnoFalls
  • 1358
« Reply #5 on: May 02, 2005, 08:50:58 AM »
bob ... that's true for track/kicks ... but x90? I dunno, them might be different :)
Offline wolf66
  • 193
« Reply #6 on: May 02, 2005, 08:53:20 AM »
But the X is just a Track/Kick with a different body.... :)
Offline SnoFalls
  • 1358
« Reply #7 on: May 02, 2005, 08:55:56 AM »
stu
if your talking length of the shaft yup ... ask me how I know ...
http://www.zukiworld.com/cgi/yabb/YaBB.pl?board=suzuki_talk;action=display;num=1110515689;start=20
Offline SnoFalls
  • 1358
« Reply #8 on: May 02, 2005, 09:01:34 AM »
sure it is ... :) ... I wouldn;t wanna guess the diffs between a JA built x90 and a CA built anything ...
FYI, some 26 spline shafts are 1/4" shorter than others ... (probably 95 only or some such) ...
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #9 on: May 02, 2005, 01:34:08 PM »
This applys to X90s too. Dans 96 X90 was 26spline.
Mike
