Rear Spool?
  • 1419 Views
Offline Urban_offroad
  • 47
Rear Spool?
« on: May 03, 2005, 05:09:57 AM »
Hey all;
I can get my hands on a spool for the back of my 91 track/kick. for $100 all set-up and inculding the 3rd member. I know that is a deal and since it's all set-up it's easy to install. I drive that thing every day in the city... so Questions:
How hard is it to put one in (in my situation)?
How bad is it on the tire wear?
Shall I expect it to chrip / click/ bang?
How is the drivablity in different weather?
Is it worth even thinking about?
Thanks all..
Wil
Offline HUMZUKI
  • 117
  • Fool!
Re: Rear Spool?
« Reply #1 on: May 03, 2005, 05:42:53 AM »
Do you live IN the city? Its easy but I wouldn't do it on in a city street.
Probably pretty bad if your making 90deg turns in the city every day. I cant even notice any unusuall wear and mines a DD with 33's. But Im not making alot of turns.
 Just the tires "barking" (basicly just 90deg turns) Othere than that it a bit harder to turn the wheel.
Im fine with it, You just have to watch gassing it around corners, b/c its reall easy to brake the tires loose in the rain and snow. I prefer it like that. I don't like how lockers lock up sometimes unexpectedly. But I rock one up front though so I can turn in 4Wheel.
Are you crazy? Youll be able to wheel through stuff in two wheel that you had a hard time in 4 wheel. And thats a STEAL!!! Thats the price of the spool alone.
« Last Edit: May 03, 2005, 05:48:03 AM by HUMZUKI »
Offline SnoFalls
  • 1358
Re: Rear Spool?
« Reply #2 on: May 03, 2005, 05:48:42 AM »
Swapping a third is easy ...
It will wear em down faster.
Yup turning tight corners with traction, one tire will have to slip (causing a chirp). No click or bang.
Turning on ice can cause the rear to break free (one tire has to slip). Not any worse than a lockrite type tho IMO.
Sure is nice offroad, but "every day in the city" might not be your best choice.
Offline HUMZUKI
  • 117
  • Fool!
Re: Rear Spool?
« Reply #3 on: May 03, 2005, 05:51:49 AM »
Sounds familiar ::) ;D
Offline Natebert
  • 1098
Re: Rear Spool?
« Reply #4 on: May 03, 2005, 07:23:01 AM »
If you drive in the city (pizza delivery driver), with an overweight truck (lots of gear), expect worn tires, and twisted/broken splines on axles.
~Nate
Offline 1bigtracker
  • 3409
Re: Rear Spool?
« Reply #5 on: May 03, 2005, 08:08:13 AM »
oh i've seen um bang before but thats just the axle shafts breaking.
I have my spider gears welded(cheap spool) and i try not to drive it on the street.   i have gone though 2 sets of axles shafts in 2 years because of twisting spines.  but i also run a 34in tall tire so i have alot of added stress.
stu
Offline SnoFalls
  • 1358
Re: Rear Spool?
« Reply #6 on: May 03, 2005, 08:42:43 AM »
I expect the 34's cause the "bang" more than the weld/spool  ;D
I've been running my spool on 31's for 4 months now (onroad, and hard offroad). No bang yet. I'm going to pull the shafts in the next month to look for signs of twist ... (and I got virgin spares to use if there is any ...).
