Mass production is hard, since this one is all machined. All the parts are machined to get an exact fit, then he sets them in a jig to get an exact fit, everything lined up perfect, etc. The machine work is $40/hr, plus the material, etc, etc, etc.I can see if he can make up a few and see if a discount can be worked. I'll talk to him this week, and I'll see what he can work out.
I guess I didn't see the "machining" ... thought it was; cut some plates, drill some holes (accurately), weld up some spacer plates. I do understand the need for thick material ...So, the work involved is making the plate (2 for each unit), and then welding in the necessary spacer plates (4 per unit). Spacers could be 2" or 3" ...Group buy? ... put me down for one (2"). Hopefully others will chime in ...
On a mass production scale, Ican have the holes punched, fast and accurate,  Make this a group buy and I can see whata bunch would cost to fab up.There is a template  that hasbeen posted here, but I don't remember who posted it....Wild
I would take one but I do NOT want the pinion offset . If  the pinion is turned upward you MUST use a constant velocity joint in the driveshaft . Also pinion angle IS directly related to traction . ( I drag race also ) You would not believe the difference pinion angle makes in traction .
