biggest tires
  • 1350 Views
Offline trackenator
  • 38
biggest tires
« on: May 05, 2005, 01:53:51 PM »
hi all. thanks 4 all the info previously. helped alot. my new ? is with my 3in body lift and 2in tj spacers all round on my 92 tracker what is the biggest tire size i could run? i have 31 x 10.50 x 15 with alot of room left.i want to go with 34 x 10.50 or even 9.50 can i ? without using a bfh? thanks all. im from toledo ohio anyone else near here? flat land no wheeling areas so it would mostly be my dd.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: biggest tires
« Reply #1 on: May 05, 2005, 01:59:49 PM »
Check out my post about the Goblin's new shoes. I just put 33-10.50x15 Swamper TSL radials on a 93 Tracker running a 4" body lift and 1.5" coil spacers. I had to do some trimming and floor pounding to clear them and I noticed tonight while flexing on a rock that I'm going to need to do a little rear quarter panel modding as well. Not counting the fulcrum-lever effect of the IFS, I'm running a total of 5-1/2" of lift and you're running 5" total. Factor in the IFS effect of the coil spacers and you and I are probably about even. If you don't want to pound/trim, then I would guess that the biggest you can go is 32-10.50. Forget the 34's, you'll need to do some serious trimming/pounding to fit them!
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
Re: biggest tires
« Reply #2 on: May 05, 2005, 02:33:25 PM »
u could probly fit 33x10.5 with a bfh (big fu** hammer). but 32's would be an easy fit. i would go with a tire that measures a full 32"s.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline Natebert
  • 1098
Re: biggest tires
« Reply #3 on: May 05, 2005, 03:37:47 PM »
A cutting torch and a welder can fit a whole assortment of huge tires, without the use of a BFH.
~Nate
