out put shaft
  • 2200 Views
Offline h22Accord
  • 17
out put shaft
« on: May 04, 2005, 08:49:17 AM »
i just got my samurai about two weeks ago and i think that there is a prob with the trany or cluch   with the motor  running and the cluch  not depressed the out put shaft on the trany the one going in to the t case  spins and there it a grinding sound  but when u push the cluch in the sound  stops and the shaft  does not sping  i know the sound is not good but  is it normal  for the shaft to be spining with the cluch not depressed
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
Re: out put shaft
« Reply #1 on: May 04, 2005, 09:49:38 AM »
First a q:
does it drive?
because I don't think that shaft should be spinning when it isn't in gear.
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Re: out put shaft
« Reply #2 on: May 04, 2005, 10:40:56 AM »
your front input bearing is shot.
Offline mesjr2004
  • 422
Re: out put shaft
« Reply #3 on: May 04, 2005, 11:23:16 AM »
or the throwout bearing is tuching the pressure plate a little causing it to spin. give the cable a little more slack and see if it stops .
the outpuit shaft is probably spinning becouse their is oil in it causing enough drag to spin the outpuit shaft.probably normal
Offline h22Accord
  • 17
Re: out put shaft
« Reply #4 on: May 05, 2005, 01:55:33 AM »
yeah it drives  ok  and it shifts just fine too
Offline zukizzy
  • 123
  • Give it a bump, see what happens!
Re: out put shaft
« Reply #5 on: May 05, 2005, 09:48:49 AM »
I would bet $ on the cluster gear bearings. and yes if there is nothing on the back of the trany or the t-case is in neutral the output will spin with the engine running trany in neutral and the clutch out
Clearly a road
Offline Natebert
  • 1098
Re: out put shaft
« Reply #6 on: May 05, 2005, 03:49:45 PM »
This must be a common Suzuki problem.
Heard it a bunch of times on Sammys.
Even heard it once on our own Kick.
We replaced clutch components, (including the throw-out bearing) and it went away.
~Nate
