4WD LOW POPPING OUT ?
  • 2650 Views
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« on: September 02, 2003, 10:33:30 AM »
OK I WAS OUT PLAYING ON A BACK COUNTRY DIRT ROAD TESTING THE 4WD FOR ANY DISTANCE FOR THE FIRST TIME .....4WD HIGH WORKS GREAT NO PROBLEMS..4WD LOW WORKS GREAT AS WELL TIL YOU HIT A FEW BUMPS THEN THE T- CASE  WANTS TO JUMP OUT OF GEAR  :o INTO NUETRAL ??? EASY FIX OR PAIN IN THE BEHIND ??? WILL BE WORKING ON KICK THIS WEEKEND SUPPOSED TO PUT LIFT IN THIS SATURDAY ..IF IT GETS HERE :'( SUPPOSED TO BE TODAY BUT SHOULD BE IN BY SAT.   MY SUPERWINCH LOCKING HUBS MADE IT IN THOUGH ;D THANKS AGAIN FOR YOUR INPUT & HELP  MATTY D.  8)
Re: 4WD LOW POPPING OUT ?
« Reply #1 on: September 02, 2003, 09:54:22 PM »
Did you body lift the vehicle? That same thing happned when I body lifted mine. The T-case shifter was touching the floor pan and when I would hit bumps, it would kick it out of low.
  • 2274
« Reply #2 on: September 03, 2003, 11:24:58 AM »
NO NOT YET! HOPEFULLY I'M DOING IT SATURDAY IF IT GETS HERE..CALMINI'S COMBO LIFT WAS SUPPOSEDLY SHIPPED OUT OF CALMINI LAST MONDAY WHICH WOULD PUT IT HERE THIS TUESDAY :-/  NOW ITS WEDNESDAY AND STILL NO LIFT >:( TRYING TO GET TRACKING # BUT NO LUCK ON THAT YET :'( I'LL KEEP MY FINGERS CROSSED ::)
Offline woof359
  • 111
« Reply #3 on: January 16, 2011, 05:43:27 PM »
minesdoing the same thing, jumps out of 4 hi and back into 2 HI, I figure its in the trans fer case and maybe a syncro if they have those. any one have an exploded view of the transfer case ?
CHUCK AND MICHELLE
Offline beagle..t
  • 1239
  • 16
« Reply #4 on: January 18, 2011, 07:06:55 PM »
mine does that but got 2" BL i just cut the floor pan so it doesnt happen
  • 4319
  • 167
« Reply #5 on: January 24, 2011, 06:25:09 PM »
What year ?  The transfer cases on the 98 & earlier are different to the 99 and later - 98's and earlier have no synchros, 99 and later have one and jumping back from 4HI to 2HI is a known problem on the 99 and later - Suzuki has a fix for it, I think it's a change of selector hub or something similar.
'98 SQ420 Grand Vitara
'05 JB420 Grand Vitara
Offline camokick93
  • 47
  • SUPPORT OUR TROOPS
« Reply #6 on: January 27, 2011, 05:15:10 PM »
Hi everyone!
I had this exact problem occuring while offroading,very anoying,I solved it completely by doing 3 things,first cutting the bottom part of the boot inside the cabin,this boot is made of a firm rubber that was enterfering with the lever putting
pressure against it popping it out of gear as soon as the tranny slightly swayed when tork was applied,just doing that made a big difference,second I installed a brass shifter sheet from LOWRANGE OFF ROAD,third,I made a .020'' shim out of a feeler
gauge and put it on top of the spring and ball of the shift rod.Happy to say after some severe trail its working flawlless.
Ah yes,I have the 4.24 gears and no body lift.
93 4door sidekick,5spd,3in calmini,ome frt coils with 2in spacers,calmini winch bumper,8500 superwinch,calmini front skid,custom rock slidders,custom belly pan,frt ome shocks with upper mount flip,4.24 t-case gears,truck painted camo,hence my user name.I have rear ARB,calmini header exh. combo to be installed soon.FOUR DOORS KICKASS
