Only place I have with in 5hrs is a Comp  :-/
Comp is only 2hrs away ÂÂ
I understand the 9" forward, Better COG for engine, tranny, & driver.  But why 6" down, Stacking a donor frame?  Height works?  Is that the desired lift for 35's?
What about the factory aluminium housing?  I'd think a Custom or GV or anvil would be necessary for that level of abuse.
Which engine and trans, 16V / 5spd? ÂÂ
Widening the stance up front to clear the 35's with the previously mentioned Modified lower A-arm mounts?
Engine & radiator on the original frame and extend the Steering shaft to meet the new donor which mounts the Box? ÂÂ
Modified Rear lower 3-link frame mounts with longer arms?  And how about the upper link? ÂÂ
YES SMOKE IS POORING OUT OF MY EARS ABOUT NOW???  Is it Feb 01 05 YETÂÂ
