Ooops
Forgot about the vacuum test, I'll cover that under the tune up, thanks for the reminder.
Depressing the clutch and holding the throttle open, to me, is a matter of opinion. I think as long as you use a consistant methodology the information will be good. I personally do it in neutral and leave the accelerator alone (had experiences with injection flooding when I floored it).
I have the same numbers in my FSM (factory service manual), problem is I have never been able to duplicate anyones compression numbers (ok rarely) even on a fresh engine. There seems to be too many variables
- Technique (everyone seems to do it different, ie: some guys spin the engine till it won't rise
any more, tends to give a little higher number)
- How much rpm are you really getting?
- How good the starter and battery are?
- How accurate the compression tester is?
I use the method I do because it is consistant and with my guage (which I know reads a little low) accurate enough as a general guide with the other engine info I listed.
Typically most small four cylinders are 150-160 psi hot in the real world when they are in good condition.
I guess if you absolutely duplicated the FSM method with a new expensive compression tester you could match the numbers, but working in the real world of what most guys have the numbers I've used are a good guide.
Thanks for the input!
Zag
