Stuck on 4X4 after body lift ??
  • 22 Replies
  • 4293 Views
Offline Mac
  • 407
  • Toys, Toys, Toys
    • 1985 Suzuki Samurai
Re: Stuck on 4X4 after body lift ??
« Reply #15 on: May 28, 2003, 06:17:08 AM »
Just extend the shifter for the transfer case, I did not need to bend mine to make it fit.
Mac
Offline UberAsuna
  • 239
  • Asuna Sunrunner 92'
    • Cranky's Ghetto My Website
« Reply #16 on: May 28, 2003, 08:11:51 AM »
Thx again ..
Ill chek it out as soon as i get home and see if it was extended or not .. If not ill chek out where i can get it done and will let you all know ASAP ...
This place is great im learning a lot :D hehe
It's A Zuki Thing, Dig It Sucka ;) :D ;D
Offline wildman jonny
  • 19
  • zuki's gone wild!
« Reply #17 on: May 28, 2003, 05:04:55 PM »
hey, I don't want to sound preachy or anything, but you'll find that even though you think you don't know much fixing cars, it ain't as complicated as the computers you work on.  maybe just a little greasier :D  two things will happen when you start working on your own rig.  one, you'll have more money to spend on cool stuff to put on it, and you don't have to work with some nut case who claims to know what he's doing.  these kits come with detailed instructions, and I'll bet you could follow them as easily as the next guy.  It has been fun reading about your exploits with your "mechanic" ;D  but I bet we'd all rather have you tell us about how you handled the project on your own.  I'll get down off my soap box now and wish you all the beast ( I mean best)  with your new set up.  What color are you going with?
« Last Edit: May 28, 2003, 05:08:00 PM by wildmanjonny »
Offline UberAsuna
  • 239
« Reply #18 on: May 29, 2003, 02:41:00 AM »
Ill keep it white because changing color will bring the price up :(  i wanted to color it  orange rust metalic kind of color  but i guess ill have to pass on this part  :'(
Offline UberAsuna
  • 239
« Reply #19 on: May 30, 2003, 11:42:14 AM »
Ok a little late hehe but i just checked it out the guy did put the extension on the 4x4 shifter ... the reason why wasnt going back enough was ... it was getting blocked by a piece of metal  that is made to hold the back of the console or somtin like that .. i removed it and VOILAAAAAAAAA :D my Uber Asuna is allllllllll good ...
EXCEPT MY MUFLER TUBE ( that last part that is long and stick the smoke out ) BROKE   :'(  im getting that fixed tomorow hehe :)
THANK YOU EVERYONE THAT HELPED
Offline chrisvitarasport94
  • 228
« Reply #20 on: September 16, 2003, 06:17:50 AM »
I'm getting my shifters extended by 2" tomorrow - will this avoid the need to mod. the console? I've already extended the holes in the transmission tunnel, to no avail.
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #21 on: September 16, 2003, 10:41:21 AM »
BRIAN THIS IS THE PIC OF HOW SHIFTERS SHOULD LOOK ;D
Offline Trac95ker
  • 22
« Reply #22 on: September 18, 2003, 09:16:44 AM »
When you have the extension welded on, you need to move the transfer case shifter back to 4x4. If it hits or almost hits the body you should have the rubber mounted part of the shifter(the black part) heated and bent foward so it clears the body and the console
Thats what I did with mine. I heated the shifter with a torch and bent it .  It took a couple tries to get it where I wanted it. I also made a slit in the rubber under the shifter boot so when I put things back together, The rubber flap did not hinder the movement of the shifter.
Drive your Tracker to the shop and bend the shifter there so you can do it rite one time!
good luck Rich
