everything seems allright, guessing its the thermostat, radiater looks ok, heat gauge is running 3/4 hot is this normal? thanks in advance!
Your description of the problem is so vague; it is hard to answer. I'd do the following things in this order:
1) check coolant level and quality.
2) check and fix faulty engine electrical grounds.
3) check thermostat [boiling water trick]
4) check clutch on fan [ at this point I just replace it]
5) have radiator flushed / checked
6) replace water pump.
Of course, there may be other symptoms that would change the order. Like a drooling water pump [fix water pump] or faulty/erratic gas gauge with a sudden change in temp [fix grounds].
Good luck, and let us know how it goes.
P.S. Don't put money into aftermarket radiators, electric fans, flex fans. You'll just mask the problem. The cooling system is more than adequate for the 1.3 and even the 1.6 when all parts are working. I've wheeled in hotter areas like Death Valley, Big Bear, and Moab [even a 100+ day in central Oregon]in extreme heat on the trail and have not had difficulty.
