Help......crank pulley bolts
  • 2072 Views
Offline sammy1987
  • putt putt
« on: September 26, 2003, 02:03:01 PM »
Well my crank pulley feel off today...... tho I didn't lose it I did lose all the bolts that hold it on.  Does anyone know or know where I can find what size bolt I need to buy?
Thanks!
Re: Help......crank pulley bolts
« Reply #1 on: September 26, 2003, 03:01:51 PM »
If memory serves me right, they
are 6 or 8 MM standard thread
about 15-20 MM long.
Did you also loose the big center bolt too?? :o
Also you will need 5 of them, tho I only have 3
in mine  ::)
« Last Edit: September 26, 2003, 03:03:08 PM by wildgoody »
Offline sammy1987
  • putt putt
« Reply #2 on: September 26, 2003, 03:30:01 PM »
I didn't lose the center one.... luckily.  ;D
I guess it would help a little if I said... 1987 Samurai, I can be a real da sometimes. :-/
I found on the web where someone is giving instructions on installing "BIGGER BADDER" crankshaft pulley and they refer to a M6x30mm.
Still looking.....  ???
« Reply #3 on: September 27, 2003, 10:33:16 AM »
Bigger Badder??? bigger turns the water pump
and alternator faster, but this is counter productive
to getting more power, bigger saps power, smaller
is what gives better power.
well get the 6M x 25 or 30s then and fixx yer zook,
try some blue locktite on clean threads, it will keep
them from backing out. I think you will have to use
the hex head screws, as I don't think there is enough
room for a socket to fit in there.
Have fun ;)
Offline sammy1987
  • putt putt
« Reply #4 on: September 30, 2003, 02:55:23 PM »
done, It was M6 and was tight but I used a ratchet and some Loctite....... Thanks.
« Reply #5 on: September 30, 2003, 03:26:03 PM »
Good deal, now it's wheelin time  :D
« Last Edit: September 30, 2003, 03:27:15 PM by wildgoody »
