front member
  • 1827 Views
Offline 1bigtracker
  • 3409
front member
« on: October 06, 2003, 10:42:00 AM »
Hey  i was wondering about the front 3 member in my Tracker.  Would it be possable to put a rear steel 3  member in the front with a locker.   J/W   lata   Stu
Offline tonka-toy
  • 154
  • tonka
    • tonka-toy
Re: front member
« Reply #1 on: October 06, 2003, 09:22:57 PM »
you can fit a samurai rear carrier with the vitara internals swapped into it
but then you need to do a mod to mount it to the front crossmember
cast steel to mild steel ( if you weld a lug to the side ) is a difficult weld to get really strong ... needs to be done by a very competent welder with the correct rods.
( i have seen one done tho .. whether it was ever fitted is another question ) :-/
« Last Edit: October 06, 2003, 09:24:36 PM by tonka-toy »
Re: front member
« Reply #2 on: October 06, 2003, 10:40:25 PM »
You can install a machined Sami Carrier into a Kick ,GV or XL-7 casing, use your same R&P and install a sami locker of your choice. The only extra part you will need is a carrier pin retaining sleeve. Hawk Suzuki Parts has everything you need to achieve this. Hutch's drive line improvement article touches on this subject.
Offline 1bigtracker
  • 3409
Re: front member
« Reply #3 on: October 07, 2003, 12:56:03 PM »
Are the front cases in the GV and XL-7 both steel?
Offline cj
  • 1276
  • I drive a really big ATV
Re: front member
« Reply #4 on: October 07, 2003, 01:48:10 PM »
They are steel in the manuals not autos until this year, now both are steel.
Offline 1bigtracker
  • 3409
Re: front member
« Reply #5 on: October 08, 2003, 02:13:18 PM »
Thanks alot.  Now its time to find one!
  ÂÂÂÂÂÂÂ
