As I understand it, the basic 2" (or thereabouts) TrackKick suspension lift involves a combination of longer springs, longer struts (or reversed top mount) and brackets to lower the front axle.
The Old Man Emu system uses longer coils and struts while the Calmini uses the original length struts with reversed top mounts along with the axle lowering brackets. Both use longer springs in the rear.
Okay so far?
So the burning question is this: What is the significance of Calmini's lowering brackets in terms of driveline wear? I see the potential increase in flex from the longer OME, but not lowering the axle would (with Calmini's brackets) would cause sharper angles of articulation on the halfshafts during flex. It would seem to me that OME struts in combination with Calmini brackets would give better halfshaft wear along with improved front flex.
Anyone got a comment on all this? I'm thinking of a suspension lift on my '93 Sidekick 4dr JLX
Ack
