Strut mounts 02 Grand Vitra Anyone
  • 1381 Views
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« on: May 07, 2005, 01:15:29 PM »
What did u guys do for the front strut mounts i got some ideas of what im gonna do but can anyone shed some light ???
01 GRAND VITARA
Offline Gear
  • 112
    • Pics and my club website
Re: Strut mounts 02 Grand Vitra Anyone
« Reply #1 on: May 07, 2005, 10:46:21 PM »
Don't touch them :)  Put in some OME struts, 40mm more travel then the stock struts and this is the limit of the front CV's unless you want to change them every few trips :)
Jeff
'03 Grand Vitara & '89 SWB Vitara
Blue bits, Locked bits, Missing bits
Offline JDMCRX
  • 1110
« Reply #2 on: May 08, 2005, 12:55:35 AM »
Cause i was thinking of getting a set of Vitra upper strut mounts and flipping them like i did on my Tracker.
01 GRAND VITARA
Offline jagular7
  • 1026
  • Jagular7
« Reply #3 on: May 08, 2005, 12:19:38 PM »
The US Vitara model has a much taller upper strut mount. I've got pics in my webshots under suspension......http://community.webshots.com/photo/107940331/145071982RZIhBI.  There is a 1.5" difference between the Trackick and Vitara upper strut mounts.
Lenexa, KS
Offline JDMCRX
  • 1110
« Reply #4 on: May 08, 2005, 03:39:50 PM »
I measure mine from the base to the top were the nut goes 3" so the us ones are smaller then ours
01 GRAND VITARA
Offline JDMCRX
  • 1110
« Reply #5 on: May 08, 2005, 03:42:38 PM »
I think what i may do is get a set of Vitra ones and cut the 3 puck flange off and weld them to the bottom of the OEM GV ones then burn the bushing out of the oem one so i can access the  bolt on the Vitra ones
01 GRAND VITARA
Offline jagular7
  • 1026
  • Jagular7
« Reply #6 on: May 09, 2005, 03:26:55 AM »
Similar to that, I'll end out with the same configuration. However, I'll be using a 1/4" flat plate between the upper mounts. With the flat plate, I can 'adjust' the space between the mounts for better droop.
Lenexa, KS
