I finally started installing my EFI into my Sammy yesterday. I have the complete donor harness and am just swapping them out. I came across a very confusing problem last night. My carb harness has a yellow w/blue wire going to my oil pressure sending unit. My copies of the wiring diagrams show the same wire on an EFI harness. There is no yellow w/blue wire on the donor harness. There is a white w/green mated with a black on a green plug on the driver's side on the new harness where the yellow w/blue is on the old. Can anyonr help me out here? Is the green plug the oil wire? Also, I understand that I can wire up the new fuel pump using the oil pressure sending unit to activate the pump, but since I have the complete harness can I just wire in a new pump where the stock pump in the tank would connect and not use a relay? I have the in tank electric pump, but not the EFI tank, so I'm going to use an external pump.
If anyone hase some pictures or diagrams for the hoses and wires on the new EFI, I would greatly appreciate them. I bought the whole EFI already removed, so I don't have a point of reference. I think I have it all hooked up ok....so far!!
