Anyone done the Front Knuckle overhaul on a ZUKI??
  • 9 Replies
  • 1737 Views
Offline Zuki One
  • 441
    • ZUKI - PICS
« on: November 14, 2003, 09:10:42 AM »
 :-/Any body done this i havent?difficulty level? best priced kit?Any info would be better then none so come on give it to me!ooh iknow and you know that their are certain tricks to this trade so if anybody knows any good secrets or tricks to make this job any easier lay it on me pleez. Thanx much!
« Last Edit: November 15, 2003, 03:34:30 AM by Bug_D »
"Sooo What shop built your rig?"hahahahhahahah    www.cardomain.com/memberpage/607888/1
Re: Anyone done the Front Knuckle overhaul on a ZU
« Reply #1 on: November 15, 2003, 01:49:56 PM »
There not too bad! you just have to clean every thing real well and don't get too impatient, I used some glue on the felts and large seals to hold them in and getting the cups out of the knuckle might be hard if you do not have a seal puller other than that just a lot of grease everywhere what a mess it can be! on going back together make sure to use a torque wrench on all the bolts even the small ones.  sky has a sale on them for oct. but maybe he does not know that it is already nov. sky-manufacturing.com 99.00  thats about half price if you can still get them there!
Offline Zuki One
  • 441
    • ZUKI - PICS
« Reply #2 on: November 15, 2003, 02:42:47 PM »
Was that 99.00 for bothsides or one ?thanx 4 the info any is worthy :D
« Reply #3 on: November 19, 2003, 06:41:18 AM »
I sent this once already but I guess it did not take? yes that is for both! check out the web site.
Offline r0ckstarr79
  • 400
  • Chevy + Zuk
« Reply #4 on: November 19, 2003, 07:44:24 AM »
I will be checking that out as well....... Thanks for the info!
« Reply #5 on: November 19, 2003, 11:28:32 AM »
Barfields......er Birfields and grease, they go together.
There has to be a better solution over these, I've never
had one apart, but a friend tells me they are like a CV
joint inside the knuckle, well you see how the TrackKick
CVs hold up :-/ , I know U-joints are for Heeps, but I
wonder if it might be a better part for heavy duty use.
??? Thoughts ..... Coments ???
« Reply #6 on: November 19, 2003, 01:03:00 PM »
I know for the toyotas they now make a bif, eliminator that looks like a dana 44 axel with the ears and a u joint that fits like a glove, too bad they won't make one for the zuk family >:(
« Reply #7 on: November 19, 2003, 01:10:12 PM »
I'm going to start some HD replacement parts,
starting with a Rear Disk Brake Axle for both
Sammies and Track/kicks, and while I'm at it a HD
front that will work for Sammies and Track\kicks
Well Sombodys got to do it ...............
Offline Zuki One
  • 441
    • ZUKI - PICS
« Reply #8 on: November 19, 2003, 04:58:29 PM »
ooh,oooh!!do it do it Iwant one! :D
« Reply #9 on: November 20, 2003, 04:49:59 PM »
Which one ?? Front or Rear ???
