Which oil filter do you use?
  • 9 Replies
  • 3140 Views
Offline bandit86
  • 1641
  • elv8rguy
« on: November 20, 2003, 07:27:51 AM »
I just bought my truck and got an oil change the day I bought it home.  For years I always used QS oil and filter without problems.  For some strange reason, I have what appears to be lifter noise above 2k rpm.  I remember the article on oilfilters and QS is basically the fram, which is bad m'kay, so which do you guys use.  Pennzoil good?  Motomaster?
« Last Edit: November 20, 2003, 07:28:55 AM by bandit86 »
Offline ntjoe
  • 50
Re: Which oil filter do you use?
« Reply #1 on: November 20, 2003, 07:44:38 AM »
I use Purilator (sp) and have no problems...plus I have heard good things about them....
Good Luck! Joe
1996 Geo Tracker 4WD
1989 Maxima SE 5 Speed
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #2 on: November 20, 2003, 08:07:11 AM »
http://minimopar.net/oilfilterstudy.html
Don't use Motomaster, they are made by FRAM.  You can check the back plates on them and see.
Go to Canadian Tire and buy the K&N HP-1002.  It'll cost almost $20, but it's the best oil filter on the Canadian market.
As for oil, I only use Mobil 1.
Offline r0ckstarr79
  • 400
  • Chevy + Zuk
« Reply #3 on: November 20, 2003, 08:53:56 AM »
I use castrol oil, and an AC Delco filter... (but my motor is chevrolet)
Offline Samurai_Hamster
  • 28
    • Samurai Hamster
« Reply #4 on: November 20, 2003, 09:00:26 AM »
NAPA/WIX filters or Purolator.  Never Fram
Offline wolf66
  • 193
« Reply #5 on: November 20, 2003, 11:58:43 AM »
I use the Mobil1 filter, its priced between the cheapo frams and the expensive K&N.
'96 Suzuki X90-4" lift-snorkle-30x9.5's on 8x15 wheels-5.12 gears-winch-added rear seat-DT header-PioneerMP3-CB-GPS-roof rack-rear mounted full size spare
Offline BigKick
« Reply #6 on: November 20, 2003, 02:02:52 PM »
I would use an AC Delco filter, but im a stickler on using factory parts. Ispeacilt fiters and engine parts.
Offline Jdawgjayj
  • 49
  • My Zuke is my Life! 140k...and counting
« Reply #7 on: November 20, 2003, 10:14:21 PM »
I like the Dark Blue Purolator.  I noticed a difference with the Check valve and idle time.  Much nicer warm up time and i feel better about that.
Haven't used a Napa/Wix yet does it also have a Check valve?
Goldmining and 4-wheeling are life.  My Sluice and Suzuki are life.
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #8 on: November 21, 2003, 06:51:56 AM »
What's "Check Valve"?
Offline Yankee Tim
  • 431
  • Who says a GV is a grocery getter?
    • Yankee Off-Road
« Reply #9 on: November 21, 2003, 07:18:33 AM »
I use Suzuki Genuine Products (SGP).  Never a problem there.
Yankee Tim
