T-Case gears. Change 2wd final drive?
  • 1789 Views
Offline BigKick
« on: November 19, 2003, 02:17:04 PM »
Im thinking about putting the calmini t-case gears in my 96 (AUTO) tracker so when I run 31s it will have some uuupppphhhhhhhh. . I just didnt want to gain alot of rpm in 2wd. It has 235-75-15s on it now and down the highway im still at 3250 at about 65mph.
Help the newbie.
Re: T-Case gears. Change 2wd final drive?
« Reply #1 on: November 19, 2003, 02:23:39 PM »
This gear set will not change 2 hi ratio, only
4 low or 2 low if you get the RRO 2 low kit.
If you want to run 31 tires, I think the Man Trans
diff gears at 5.13 will bring you back to stock
gear ratio as with 205 tires when new.
« Reply #2 on: November 19, 2003, 09:54:54 PM »
Wild,
Have you done this install? How difficult is it once you have your T-Case out?
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #3 on: November 20, 2003, 09:13:34 AM »
Ive been running this kit for about 2 months and will have a full write up on Zukiworld next month.
Mike
PSST It kicks ass... you should get one installed before moab. ;) Just what you wanted to hear huh, more stuff to buy before moab.
;D
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #4 on: November 20, 2003, 09:16:35 AM »
I guess I didnt answer you question did I?  :P Once it was out it took about a half hour.
Mike
Offline nighthawk801
  • 51
  • Zuki Lover
    • ClubGM
« Reply #5 on: November 20, 2003, 05:05:25 PM »
I might actually get to go to Moab this year, finally. When do you guys usually go? Zukefari?
90 Sidekick 2-dr w/ hardtop, 250k mi.
2-3" susp., 1.5" body, 4.4:1 low, ARB rear, onboard air.
http://www.clubgm.com/redzuki
89 Sidekick softtop Stock, 180k mi.
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #6 on: November 21, 2003, 10:35:07 AM »
We will be pulling in to Moab April 2nd late in the afternoon. We generally pull out on the am of the 10th.
Mike
« Reply #7 on: November 23, 2003, 10:15:46 PM »
Mike,
My first thing is definately POWER STEERING!!!!! I dont think I want the ol-manual steering wheel snatch climbing that stuff :o Then I will look at the 2-lo Kit. Maybe that wil be the first mod at my new shop (oops, I meant house :P) Looking forward to the write up this month.
