Wild Doors
  • 28 Replies
  • 5596 Views
Offline zukizzy
  • 123
  • Give it a bump, see what happens!
Re: Wild Doors
« Reply #15 on: January 03, 2005, 03:23:01 AM »
Those doors look sweeeet ;D. Ya Wild for some reason I don't think you would have wanted those doors on this weekend. I,m still trying to get the mud off the kick.
see ya,
  Kevin
PS Zukizzy I heard that your shop is in menife I live off clinton keith if you ever need help in the shop let me know.
Kevin
I see your splash all over the place, passed ya the other day with the sammy in tow behind my red cheby on Los Alamos. I will need a little measurement help with the Kicktrack stuff I will give ya a pm . trying to dig out of the mud right now.
Thanks
Wayne
Clearly a road
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: Wild Doors
« Reply #16 on: January 03, 2005, 09:15:08 AM »
You gotta paint them things red Darin!
And maybe add some chrome-yellow clamp-on mirrors!
:o
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Re: Wild Doors
« Reply #17 on: January 03, 2005, 10:01:55 AM »
  see ya,
  Kevin
You remove the mud from your Track/Kick ???
That's just wrong   ;)
Wild  ;D
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: Wild Doors
« Reply #18 on: January 03, 2005, 10:22:15 AM »
Well 2000#'s is alot of mud. I could hardley get up the hill to come home.
Re: Wild Doors
« Reply #19 on: January 03, 2005, 10:26:36 AM »
That just means your not jumping enough
;D
Offline zukizzy
  • 123
Re: Wild Doors
« Reply #20 on: January 04, 2005, 01:46:22 AM »
Ok so left to right here are an asortment of pins we tried for removable Kick doors.
1/4 " cotterless hitch pin. too small but the prefect pin if you can find one in 5/16"
3/8" cotterless hitch pin. I thunk I could take out the bushings in the hinge and try this pin but no go. get one that is 5/16"
5/16 uiniversal clevis pin with a spring hitch pin to keep it in place. Thins will work but is hard to get in and out due to the lack of a grab ring. also the top one has to go from the bottom up due to clearance. This is why the spring pin.
5/16" spring clip pin. Again a great pin easy as any of them to get in and out but the spring clip gets in the way of the door if you install it from the outside, or the rubber seal if you install it from the inside, which is easier anyway. It could be modified with a BFH to clear but the cotterless hitch is prefect. Im' looking for a bulk supplier now.
Hope this helps
Wayne
Clearly a road
Offline keith
  • 1176
Re: Wild Doors
« Reply #21 on: May 11, 2005, 01:38:32 AM »
Did these doors ever reach production status?
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
Re: Wild Doors
« Reply #22 on: May 11, 2005, 02:17:07 AM »
All you gotta do is PM Zukizzy and order some ;)
www.Zuwharrie.com[/url]
Where the road ends........... Zuwharrie begins !!!
Offline Natebert
  • 1098
Re: Wild Doors
« Reply #23 on: May 11, 2005, 03:50:47 AM »
Are they supplied with proper 'pins' ?
~Nate
« Last Edit: May 11, 2005, 08:47:04 AM by natebert »
Offline hcgalvin
  • 1695
    • Granite Path
Re: Wild Doors
« Reply #24 on: May 11, 2005, 08:17:07 AM »
Hope this helps
Wayne
Heather Galvin
Offline Natebert
  • 1098
Re: Wild Doors
« Reply #25 on: May 11, 2005, 08:52:54 AM »
Fortunately, those brain dead error messages that IE supply aren't visiable in Firefox.
No little red 'X's for me!
~Nate
« Last Edit: May 11, 2005, 08:53:13 AM by natebert »
Offline hcgalvin
  • 1695
    • Granite Path
Re: Wild Doors
« Reply #26 on: May 11, 2005, 08:59:18 AM »
~Nate
Yup, in Firefox.. it just completely ignores the fact that there may have been an image there... so there's nothing at all..
Heather Galvin
Offline Natebert
  • 1098
Re: Wild Doors
« Reply #27 on: May 11, 2005, 08:59:38 AM »
But wait, somebody PM'd me !!!!
Now I can enjoy it like the rest of you!
Glad that Firefox doesn't pollute my pages with images I can't even see to begin with.
~Nate
« Last Edit: May 11, 2005, 09:01:48 AM by natebert »
Offline explosivo
  • 3157
Re: Wild Doors
« Reply #28 on: May 11, 2005, 09:51:39 AM »
Ow, damn! My eyes!
Someone needs to turn on ClearType for sure :P
omghi2.us[/url]
