engine idle 8v
  • 2040 Views
Offline Mike71
  • 1449
engine idle 8v
« on: December 15, 2003, 08:36:33 AM »
engine idle sometimes is spuratick?? bad spelling i know sry
sometimes when its cold..mabey been run 5-8mins ill be a stop light or stop sign and the rpms will hit mabey 200-400 its hard to tell they will just drop the needle wont wave from 200-900 itl just stick at 200 the engine wont studder or shake or sound crummy( well any worse then the 8v already studders and clatters on like a tractor lol)
if i put my foot on the gas and rev it up then let it fall back sometimes itl stick to 800-900 sometimes itl go back to 200..???? kinda weird it wont die or anything first engine i have seen thatl bog to 200 and not shut off lol if my dads car falls below 750 for more then a seccond itl die...mabey my 8v is stonger then 351w?
i am trying to sort all the problems with my car out now since i have lost my job i dont want anything to come up and bite me when im running low of funds so any help would be cool if its normal then sry for wasting bandwidth
  • 6558
  • 64
Re: engine idle 8v
« Reply #1 on: December 15, 2003, 10:39:12 AM »
Maybe water in fuel? Does it happen when the tank is more empty?
Offline Mike71
  • 1449
Re: engine idle 8v
« Reply #2 on: December 15, 2003, 03:44:38 PM »
u know...it happens when i fill up now that i think about it...like i just fill up pull out get mabey 100 feet to the light and itl do it....wow i never thought of that
could it be the gas im putting in? its shell incase that helps
ty for helping =)
  • 6558
  • 64
Re: engine idle 8v
« Reply #3 on: December 16, 2003, 12:45:32 AM »
ty for helping =)
Try one of those fuel additives that removes moisture. The only one I can think of is heet. I'm sure there's more...
Good Luck, Eric
Offline Samurai_Hamster
  • 28
    • Samurai Hamster
Re: engine idle 8v
« Reply #4 on: December 16, 2003, 01:01:36 PM »
IAS motor going bad?
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
Re: engine idle 8v
« Reply #5 on: December 16, 2003, 01:08:18 PM »
Based on what you said in the last post, it could be the evap system. If the purge valve doesn't work to let the charcoal canister empty back to the tank, the fuel condensation maybe backing into the intake. You can test the purge valve and check the lines going to the canister. There shouldn't be large amounts of fuel.  :)
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
Offline Speedracer7c
  • 2210
Re: engine idle 8v
« Reply #6 on: December 17, 2003, 03:31:22 AM »
I got some shell gas last week and it caused my motor to fluctuate about 500 rpm.....the tank only lasted about 100 miles cause i had to keep it to the floor the whole time on the highway....it was horrible. I'd try different gas cause I did and everything is back to normal.
