Engine Died
  • 1821 Views
Offline techie
  • 80
  • On the mountain anytime
Engine Died
« on: March 25, 2005, 02:46:29 PM »
Had the 1.6 16v in for a while. Was driving the other day and the engine quit and then picked up immediately. Thought a little about it but it ran fine for a few days and then it did it again, this time it sputtered a bit more then picked up and got home fine. Went to start the next day and it started and then quit and now it won't start at all.
What could it be?
Offline Blasted
  • 63
  • Yea.. its a Kick.. Keep dreamin.
Re: Engine Died
« Reply #1 on: March 25, 2005, 03:27:54 PM »
Check for fuel.. Pump might have went.
93 Sidekick 2Dr.  2"body lift.  30" Tires. 1.5" Coil spacers. 4 door coils. 2"strut spacers. K&N Factory replacement filter. 2.25" Cat back, with glass pack.  Custom ground High torque Cam shaft. And CB for talkin trash.
Offline techie
  • 80
Re: Engine Died
« Reply #2 on: March 25, 2005, 03:35:50 PM »
Checked the pump, replaced the filter and so on, we're getting fuel but still nothing. When it fires it sounds pretty rough but won't run.
Offline derekj
  • 784
  • i'm the canadian guy eh?
Re: Engine Died
« Reply #3 on: March 26, 2005, 04:14:00 PM »
check to see if your timing belt skipped a few teeth - how is your spark?
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline techie
  • 80
Re: Engine Died
« Reply #4 on: March 28, 2005, 02:27:33 AM »
Getting some spark but I'm not sure of the time lapse between an individual plug firing when turning over.
Offline techie
  • 80
Re: Engine Died
« Reply #5 on: May 11, 2005, 09:52:02 AM »
What could it be?
Forgot I had this post but I figured out the problem. It seems that the crank angle sensor on the 16v went. The kicking out and then starting up again I guess were just the initial symptoms of the problem before it went completely.
