1995 Suzuki Truck Sidekick 4WD 1.6L 16V MFI SOHC 4cyl high/low rpm when in park
  • 541 Views
Offline gee wizz
  • 9
 I have a 1995 Suzuki Truck Sidekick 4WD 1.6L 16V MFI SOHC 4cyl just started to have this problem i start it up in park it revs up to 2 rpms put in drive or reverse no high rpms . If i let it in park to run it revs to 2 rpms  then starts to rev up and down from 1-2 rpms. i got new map sensor,cleaned and checked IAC, cleaned throttle body. And still same problem any help afraid to drive don't want to get broke down .
Offline RJkick
  • 631
If it starts really going high and low and stalling that could be the ECM.  Other than the RPMS it drives OK?
92 Sidekick 1.6L 16v Calmini\OME 4.5" lift 3" Body Lift OME962 springs in front w\.75" spacers OME955 in rear w\1.75" spacers Extreme Duty Strut Eliminator kit and rear ProComp MX6 Shocks 31X10.50 Nexen M\T   Thorley Header   2" exhaust  Calmini front truss bar and stabilizer and skids   Custom Bumpers and Rock Rails  Limit Straps
Offline gee wizz
  • 9
     Found out the problem was  vacuum  leak in hose from ISC hose
Offline RJkick
  • 631
awesome
