Steering wheel replacement for 95 Sidekick
  • 513 Views
Offline LarryK
  • 33
« on: November 22, 2022, 05:19:55 AM »
What kind of bolt pattern am I looking at?
  • 4317
  • 167
Re: Steering wheel replacement for 95 Sidekick
« Reply #1 on: November 22, 2022, 08:04:51 AM »
OEM Suzuki steering wheels, as, I believe are most OEM steering wheels, fit on a tapered splined shaft - at least, that's how they were prior to the advent of airbags, I haven't removed a steering wheel from an airbag equipped Suzuki so I don't know how those are attached to the column.  If your vehicle is not airbag equipped, you should be able to get a hub adapter to fit whatever bolt pattern you need, Suzuki seems to use the same spline across a wide range of vehicles, however, turn signal cancelling arrangements can be different, so there are different hub adapters available in any given bolt pattern.
'98 SQ420 Grand Vitara
'05 JB420 Grand Vitara
