my last post was for 1995 sidekick 4wd
  • 525 Views
Offline gee wizz
  • 9
« on: September 17, 2022, 02:21:33 PM »
 i have tried every online new car parts site and can't find a pair of front struts  with springs attached i don't want to use a parts shop rental tools to compress spring  any help of a site?
  • 4317
  • 167
Re: my last post was for 1995 sidekick 4wd
« Reply #1 on: September 18, 2022, 05:29:37 AM »
As I said in response to your other post - the Sidekick does not use a "coil over" type strut, so a strut with springs attached is not offered - the coil spring sits between the control arm & the frame, not on the strut.  You don't need a spring compressor to replace the struts, a pair of jack stands, a jack and the hand tools to unbolt the strut are all that are required.
After you put the car on the jack stands, put the jack under the control arm and use that to prevent the spring from unloading.
'98 SQ420 Grand Vitara
'05 JB420 Grand Vitara
